  #161
Old 11-14-2006, 03:13 AM
fourfourto's Avatar
Default Re: Master Flow MF-1050 Air Compressor Installation w/ pics
Yeh . To remove you must unscrew air cleaner.
Old 11-14-2006, 08:41 PM
jp's-h3 jp's-h3 is offline
Yes, a bit of a prob!
I take The filter off and am able to get my hand (with a little effort) in there to get at the clips. (I have long fingers!)
Old 11-15-2006, 01:05 AM
Jeff G's Avatar
Jeff G Jeff G is offline
Jeff G is off the scale
Dumb question. Where can I find a Master Flow MF-1050? I've searched the web over and can't find one. Thanks for any help.
Jeff
Old 11-15-2006, 01:14 AM
SR1355's Avatar
SR1355 SR1355 is offline
Pep Boys carry them and they are avail on ebay but pricng is better at Pepboys.
Paul M
SR1355
Old 11-15-2006, 01:16 AM
fourfourto's Avatar
Jeff
did you try ebay ?
Pep Boys has it cheaper
Long thread but info is in there
Old 11-15-2006, 02:15 AM
H3slate's Avatar
H3slate H3slate is offline
Also look for the superflow compressor, it is the same compressor just with a different model #. I even double checked with the manuf. before I bought it. I got mine online at a parts place, but found them at G.I. Joes later on.
Old 11-15-2006, 02:26 AM
Jeff G's Avatar
Thanks for the help. I typed in Masterflow instead of Master Flow and found all kinds of results.
Old 11-16-2006, 05:45 AM
Jeff G's Avatar
I left my house in the Smoky Mountains this afternoon and stopped in one of the Pep Boys in Knoxville. Got the last one they had. Thanks for the advice.
Jeff
Old 11-16-2006, 04:55 PM
fourfourto's Avatar
Jeff make sure you dont drill the 4th hole in the fusebox cover.
And buy a quick connect at radio shack for the power wire.
Are you going to run a line to the frame or are you just going off the compressor with the airhose ?.
Old 11-17-2006, 01:58 AM
Also make sure to run a safety wire to the air filter so that any vibrations don't rattle the cover off.
good luck, let us know if you need any other guidance!
Old 11-17-2006, 03:03 AM
fourfourto's Avatar
JP mines been on fine doesnt seem loose I havent touched it since install.
Old 11-17-2006, 03:56 AM
Jeff G's Avatar
Definately no fourth hole!! I'm going to run a line to the frame. Is there any one place better to come out with the air, such as the side, front rear, etc.? I'm also planning to swith it from inside the truck so the hood doesn't need to be popped for anything.
Old 11-17-2006, 04:29 AM
fourfourto's Avatar
Look through this thread there are pics of side install.
Inside switch sounds good.
I do use the gauge on compressor(about 5 lbs off) most of the time .
Also compressor has more power with the truck running and will stay cooler with the hood open.
Old 11-17-2006, 06:10 PM
Better safe than sorry!
Old 11-17-2006, 06:20 PM
You could run the air hose down along the drivers side frame rail and run a splitter off of that to the drivers side. I'm thinking of doing that myself! as for that fourth hole one the fuse box cover, GO FOR IT, It adds character!
Old 11-20-2006, 04:51 AM
Jeff G's Avatar
I got mine installed this afternoon. I used a relay and switched it inside the cab. It's a nice compact install. I appreciate the info.
Jeff
2006 H3 Lux/Offroad - Slate Blue - Ebony Leather - Sunroof - Brush Guard - Husky Rear Mat - Petz Cover (so my Wheaton Terrier can ride with me) - GOBI Stealth Rack - PIAA Lights - DC/AC Coverter - Truxxx Leveling Kit - DC1 Wheels - 35"X12.50" Toyo Open Country AT - Step Bars - Onboard Air - Chrome Fire Extinguisher
2003 Mercedes Benz S500 AMG
2003 BMW Z3 - Wife's
Old 11-20-2006, 05:14 AM
Jeff
Glad to help!
Old 11-23-2006, 05:16 AM
Congrats Jeff!
I'm sure you will get allot of use out of it!
Old 11-27-2006, 03:38 PM
Jeff G's Avatar
Pics of my install:
Old 11-27-2006, 09:21 PM
Nice set up Jeff!
Can you give a little info on the fittings / steel braided hosing from the pump to the coupling mounted on the frame rail?
Thanks!
