Old 11-17-2006, 03:21 PM
JetEyeNite JetEyeNite is offline
JetEyeNite is off the scale
Question How to remove Rear Cargo inner panel??
I need to repair my rear license plate holding assembly.
I searched and there weren't any direction on how to remove the inner panel. I know OrangeCrush have done this before.
Can someone please help????
thanks in advance..
04 Pewter Lux
Old 11-17-2006, 03:47 PM
Wilstruck's Avatar
Wilstruck Wilstruck is offline
Wilstruck is on a distinguished road
Default Re: How to remove Rear Cargo inner panel??
I shall be attempting same repair shortly and let you know.
Wil
04 White Lux
93 Supercharged Lightning
Old 11-17-2006, 04:05 PM
ree's Avatar
ree ree is offline
Is this what you want? Note pull strap removal procedure is trivial. And numbering got a little messed up when I pasted it in here.
Document ID# 840810
2003 HUMMER H2
Trim Panel Replacement - Liftgate
Removal Procedure
  1. Remove the lift gate pullstrap. Refer to Pullstrap Replacement - Liftgate .
  2. Remove the bolt that retains the cargo tie down
  1. Remove the 2 push pin fasteners at the bottom edge of the liftgate trim panel
  2. Gently pull on the lift gate trim panel to disengage the retaining clips.
  3. Remove the lift gate trim panel from the vehicle.
  4. Inspect for broken or missing retaining clips and replace the clips as necessary.
Installation Procedure
  1. If the vehicle is equipped with tie downs and the service replacement part does not have the down holes, drill out the etched holes on the rear of the liftgate panel.
  2. Install the lift gate trim panel to the vehicle on the liftgate trim panel.
    1. Align the retaining clips on the liftgate trim panel with the openings in the lift gate.
    2. Gently press inward on the liftgate trim panel to engage the clips.
    Notice: Refer to Fastener Notice in Cautions and Notices.
  1. Install the cargo tie down and secure with the tie down bolt.
    Tighten
    Tighten the bolt to 9 N?m (80 lb in).
  2. Install the lift gate pullstrap. Refer to Pullstrap Replacement - Liftgate .
  3. Install the 2 push pin fasteners at the bottom edge of the liftgate trim panel.
'03 pewter base H2
Old 11-17-2006, 04:07 PM
ree's Avatar
ree ree is offline
If it's just a loose plate holder, I think others have just used sheet metal screws to reattach it rather than go remove the interior trim. No guarantees on that approach though.
'03 pewter base H2
Old 11-17-2006, 04:18 PM
ree,
Yes... that is exactly what I was looking for... Thank you very much..
How do you go about just reattaching the rear license plate holder w/ screw? It seems there isn't much behind the black plastic assembly that is holding the license plate.
thanks again..
04 Pewter Lux
Old 11-17-2006, 05:09 PM
ree's Avatar
ree ree is offline
Originally Posted by JetEyeNite
ree,
I'm not sure. It's a vague recollection of something that a banned (globally ignored) individual did. So I didn't bother trying to search for it.
'03 pewter base H2
Old 11-17-2006, 08:51 PM
mdoyle mdoyle is offline
mdoyle is on a distinguished road
I have a similar problem with the license plate holder, it's coming loose at the top and appears a mounting boss is broken inside.
The problem comes from the door supports, once it's near closure they allow it to slam shut which stresses that panel. I just haven't had the time lately to take it all apart and fix it properly.
Old 11-18-2006, 01:16 AM
Wilstruck's Avatar
Thats the same problem with mine that i must fix. Must be a defect
Wil
04 White Lux
Old 11-18-2006, 10:27 PM
H2inMD H2inMD is offline
H2inMD is off the scale
Same problem here. I was thinking of just putting some new double sided tape on the liscense plate holder, maybe it will work.
REE, do you have a diagram of the liscense plate holder assembly? thanks
Old 11-18-2006, 11:12 PM
ree's Avatar
ree ree is offline
This is all I can find.
'03 pewter base H2
Old 11-19-2006, 04:32 AM
HummBob's Avatar
HummBob HummBob is offline
The license holder thingy is a PIECE OF CRAP!!
I've had mine replaced TWICE under warranty so far, but I'm worried about the AFTER WARRANTY times!!
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 11-19-2006, 01:24 PM
Wilstruck's Avatar
Im thinking of trying to line the back of the plate assembly with a thin foam or rubber to absorbe some of the shock from the gate slamming. hopefully this will keep it from braking again.
Wil
04 White Lux
Old 03-14-2007, 07:30 AM
ParchedMosquito ParchedMosquito is offline
ParchedMosquito is off the scale
Got any pics for the passenger side panel in the cargo area?
I have a squeak due to a bad back-up camera install (previous owner) and need to get in there to see whats rubbing..
Earth first. We\'ll mine the rest later
Old 03-14-2007, 07:53 PM
Here's my take on whats happening to the license plate holders- when the lift gate is slammed the inner panel continues to move which stresses the plastic holder mount.
I've found some epoxy repair putty at Home Depot and its worked well on other projects, I plan to give it a try on the H2 plate holder next.
Old 03-14-2007, 08:10 PM
Tallowood_Air's Avatar
Tallowood_Air Tallowood_Air is offline
Tallowood_Air is on a distinguished road
where do you get stuff like this???
2007 SUV LUX All-Terrain Blue
Polished Radix Magnacharger; 2.8" pulley; Tuned by HESCO; Custom 4L80E "Raptor" by PACT
GM 2500HD Efans on SPAL controler; K&N filter element; Dynatech Headers + Cats; Magnaflow cat-back
37" Kumho Road Venture MT KL71 on 24" ZINIK Mazotti
Pioneer AVIC-Z1 HDD navigation; 2 x 12" JL W6; Custom Box w/ Lights
Old 03-19-2007, 03:41 PM
ree's Avatar
ree ree is offline
Thanks to f5fstop, I have a GM SI DVD which has a lot of exploded parts views on it.
'03 pewter base H2
