Old 11-05-2006, 11:00 PM
rjmoose rjmoose is offline
rjmoose is off the scale
Default Re: H3 MPG < H2 MPG
Have you checked your Influx Regulator (or the Soil Compilator if you do a lot off roading)?
It could be the Muffler Bearings....if that is the case, you MUST use a Left-Handed Hammer to repair it.
Old 11-13-2006, 09:05 AM
TRUST on old man...
IT AIN'T the:
tires
roof rack
torsion bars
OR
hamsters
Its one of two things:
#1 YOUR ANCHOR is DRAGING
#2 You have a tuning problem
RYD
Old 11-13-2006, 10:45 PM
One thing to keep in mind is that as you increase the height of the front of the vehicle, the front axles/CV joints become more misaligned. The efficiency of the CV joint drops as the ends become more off axis. This increases your drivetrain losses resulting in less power to the wheels and lower fuel economy. This is the same philosophy as setting the proper driveshaft and pinion angle or torqueing a bolt using a universal. This may not may the complete cause of the issue here though.
For example, the Corvette (IRS rear) has about 2% worse drivetrain loss than an F-body (solid axle) due to the 4 CV joints in the Corvette's IRS.
Old 11-13-2006, 11:19 PM
Desert Dan's Avatar
Gee
I hope Corvette doesn't go back to a solid axle
It's the 35" tires causing the drop in mpg. The hamsters can't take it
Not likley the cv joint angle in your case.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 11-19-2006, 04:34 AM
Linus Gump's Avatar
Linus Gump Linus Gump is offline
Linus Gump is on a distinguished road
Originally Posted by marin8703
the engine has nothing to do with how much its going to burn relatively. Its called the conservation of energy. If you have the same mass, and try to move it with a smaller engine, it will be at higher rpm, but use less fuel per revolution because of the smaller size. A larger engine would do it at less rpm (thus seems easier) however because of its larger size uses more fuel per revolution. 3.5L to 6L almost double per revolution. Although its more complicated than that, i just wanted to make the point.
Tires however could be an issue.
The size of the engine has everything to do with how much fuel it consumes, assuming everything else is equal. Power= PLAN where P=Pressure in the cylinders, i.e. air pressure past the throttle body, L=Length of stroke, A= Area of the piston head, and N= number of times. Since the air fuel mixture reamians constant reguardless of the throttle position or RPM, for every given volume of air going into the cylinder there is a proportional amount of fuel. Air pressure in the cylinder is regulated by the throttle plate. When it is closed, and the engine is at idle, very little air makes it past the plate and you have low pressure in the cylinders. This shows up as high vacuum on a vacuum gauge, or low pressure Manifold Absolute Pressure (MAP) gauge. When the throttle plate is fully open, then there is high pressure, almost full atmospheric pressure, in the cylinders. This shows up as very low vacuum, or high pressure on the MAP.
Now, to put this in prespective of the Hummers, the 3.5L is at a certain throttle position and a certain RPM producing a certain amount of power during cruise. Put the 6.0L at that same RPM and throttle setting and it will produce more power because of it larger size. Thus, the 6.0 can perform more work for the given RPM and manifold pressure (throttle position), but at a cost of more fuel. If you want it to consume the same fuel as the 3.5L at the same RPM, you must change the throttle setting to one with lower manifold pressure to match the power output of the 3.5L (That may be physically imposible depending on the RPM, target fuel consumption, and the brake fuel consumption of the 6.0L). If you increase the load on the 3.5L, it will require a higher manifold pressure (throttle open wider) and consume more fuel to maintain that same RPM. So, if the H2 cruises with a certain aerodynamic load, mass load, and rolling resistance and gets a certain fuel economy, it is entirely possible for the H3 to increase its aerodynamic load, mass load, and rolling resistance to the point that the engine is working hard enough to consume more fuel that the larger underworked vehicle.
As to gearing, assuming everything is eqaul, and the engines are producing an idential percentage of their total power, then yes, the smaller engine would have to have gearing to work in it's favor, and it would have a higher RPM. But, by changing the tire size without regearing the axles, you have changed the effective gearing to something unfavorable to the smaller engine, thus increasing it's load and throttle position just to maintain the same RPM.
Old 11-19-2006, 07:01 AM
In short one f'ed up H3. Worst of both worlds, both gutless and getting 9mpg. That H3 needs to be returned completely back to stock configuration for a fresh start.
S.
Old 11-22-2006, 07:48 PM
Bully13's Avatar
Bully13 Bully13 is offline
Don't feel bad Tim. Sometimes I forget and leave the E-Brake on too.
Old 11-22-2006, 09:21 PM
I have 35's
I have four turns on the t-bars
I got 15mpg on my latest long distance trip, 1223 miles, at 80mph.
Tim,
have you changed you air filter????
Old 11-23-2006, 12:10 AM
S.
Old 11-23-2006, 12:26 AM
Originally Posted by f5fstop
yep...
Old 12-13-2006, 06:07 PM
H3.007 H3.007 is offline
I have the stock 33s, t-bar turns levelled to rear, a brush guard, rear bumper bar, factory off road lights, and vent shades. My mileage had been in the estimated range and still is, for the most part, on highway trips. However, after the 6,000 mile mark, I have noted a definite decrease in city mileage. I am not quite sure why although I had been driving it quite aggressively in expressway conditions, frequently kicking high rpms. On my current tank, I am going to try to stay out of "afterburn" and see what the mileage is as I suspect of you drive it like a granny, you'll get the best MPG, but if you drive it like Ricky Bobby.... well, you get the point.
Has anyone ever conducted a test on gasoline grades and what gets the best mileage in the H3 under normal driving conditions?
Old 12-14-2006, 03:42 AM
Alan06SUT's Avatar
Originally Posted by timgco
WHy is my H3 with 35" tires getting 3-4 mpg worse than my H2 with 37" tires? I'm only geting around 9mpg in the H3 and am getting 12-13mpg in the H2. They both have the same tire tread, both have stealth GOBI racks, both get gas from the same station, and I drive both the same.
Well this proves the H2 is better than the H3.
Old 12-14-2006, 07:49 AM
Diabolus's Avatar
Diabolus Diabolus is offline
Diabolus is on a distinguished road
A Pathfinder with a 4.0L 270 hp V6 weighing almost the same as the H3 can get 16/23 mpg and is still pretty quick(0-60 in 7-8secs) for an SUV. Why can't the H3? I have my fingers crossed the 08 H3 comes close. Of coarse the H3 kicks it's arse in the off road dept., but why can't the H3 excel in both on and off road?
