Old 05-05-2004, 11:57 AM
sbmike's Avatar
sbmike sbmike is offline
sbmike is off the scale
I use a trailer hitch cargo rack from time to time and having tail pipes that come straight out the back will just not work for me. I learned from experience with my Durango that having a straight pipe can fry things on the cargo rack (hell, it burned the paint off the cargo rack!). Do any of you know any manufacturers who make an efficient exhaust system with a tail pipe that aims downward rather than straight out the back?
04 Yellow Lux with Adv stuff like air suspension and full brush guard.
sbmike's Avatar
sbmike's Avatar
Old 05-05-2004, 12:07 PM
FrgMstr FrgMstr is offline
FrgMstr is off the scale
Any decent muffler shop with a bending mahcine should be able to route your exhuast where you want it. Of course restriction comes into question but as long as the bends are not severe, you sould be set.
________________________
This place sucks now, bye.
Old 05-05-2004, 12:26 PM
Bevo Bevo is offline
Bevo is off the scale
Check out the Corsa Off-Road system. It matches the stock exhaust exit to retain the clearance and approach/departure angles.
Yellow 03 Adventure w/black Grill, UM8 Touch Screen Navigation Radio, U2K XM Digital Radio, Remote 6-CD Changer, JBA Titanium Headers, Corsa Off-Road Sport, Airaid Filter & MIT, Nology Wires & Plugs, S&P Pro-Flash, Warn 9.5ti w/X-Line, Toyo Open Country M/T 37x13.5.
Old 05-05-2004, 01:05 PM
CRUZMISL CRUZMISL is offline
CRUZMISL is off the scale
what he said.
Old 05-06-2004, 12:47 AM
HHummer's Avatar
HHummer HHummer is offline
HHummer is off the scale
Just an additional note on the Corsa - you can also switch the tips, so if you like the look of the chrome tips just order the optional off-road tip and then switch when you install the rack of go extreme in off-road. Best of both options.
Old 05-06-2004, 12:11 PM
sbmike's Avatar
Thanks for the responses. Now all I have to do is come up with the money. C'mon Powerball lottery!
Old 05-06-2004, 10:56 PM
Nighthunter Nighthunter is offline
Nighthunter is off the scale
I own a Auto Shop In Woodbridge VA . I installed a magnaflow system with custom polished stainless Tailpipes with oval tips turned towards the groun hte same system installed on your Hummer for 675.00. Iwork by appointment only. PM if interested.
Nighthunter
