Old 11-29-2006, 06:32 AM
dochummer's Avatar
Default Re: Hot Shot Washer Fluid Heater
doubt it...I don't think it's hot enough to do that....you'd have a better chance of getting a rock chip than to have the water break the windshield...
'03 H2
Old 11-29-2006, 10:44 AM
Vettster Vettster is offline
Originally Posted by Beonly1
OK, guys I've been lurking the forums, looking for potential products to add my future H3. I certainly don't know the technical issues as well as you do. However; I came across the following post on the H2 forums and was trying to get a sense of whether these are aberrancies and most owners are happy or this is commonplace?
10-22-2006, 11:02 PM
dochummer
Hummer Guru Join Date: Nov 2004
Re: PARTSGUY - NEED HELP PLEASE
The actual button to tom it on and off would be nice too! Anybody have problems with their hotshot. Mine stopped working last month. Sometimes, the light just flashes, other times, no light at all.
Anybody have the limited edition operating instructions for the hotshot unit? I spoke with the hotshot people, and they said that i most likely overheated the unit, that's why it's not working any more. Said that I didn't prime it. The manual says that you need to prime it before using after initial install....wasn't aware that I was supposed to prime it every time I use it....Is that the way it is with the limited edition installs?
Vettster
Hummer Veteran Join Date: Jul 2006
Is the factory installed one named "Hotshot"?
If so, mine has not worked since day one.
I took it back to the dealer and after 3 days in the shop, it worked a total of two times.
The instructions are pretty vague. It tells you to push the button (No kidding) and nothing else.
I know I'm gonna be really pissed once the snow starts falling here.
Hotshot = POS
Old 11-29-2006, 11:47 AM
I do see a problem with the prime in the unit, but not under normal operation. If primed correctly upon initital install, the check valve should keep the unit filled, since it prevents the fluid from flowing back to the reservoir.
However, the auto mode, automatically squirts the fluid onto the windshield from the Hotshot unit. Unless the hotshot unit also has a pump to draw fluid from the reservoir, it would run out of fluid, till you manually pushed the washer switch to push fluid from the reservoir to the unit.
I will call hotshot today, since their technical support website does not work and ask.
The ones equipped on vehicles from GM are incorporated into the entire washer system.
Old 11-29-2006, 02:41 PM
K9sH3's Avatar
K9sH3 K9sH3 is offline
Thank you.
Yeah I have had my share of rock chips.
Old 11-29-2006, 04:55 PM
bjc's Avatar
bjc bjc is offline
bjc is off the scale
I was going to wait and go with one of the new wireless units that they showed at SEMA, but it sounds like the wired version doesn't even work that well.
Hmmm...
Birch White H3 Manual, Adventure Package, Sunroof, Trailering Package, Off-Road Lamps, Splashguards, Black Tubular Assist Steps, Black Crossbows, Mudder Mats, Ski Rack, Warn XD9000 w/ DOI Hawse Winch Bumper, DOI Prototype Skid Plates, M101A1 3/4 ton trailer.
Old 11-30-2006, 01:07 AM
Looks like their website is right on par with their product.
Yep, and they don't work either.
Old 11-30-2006, 01:14 AM
They only have one tech, so he is supposed to call back....
I may just run warranty on these and see how many GM has replaced. I'm getting curious, but I have to admit, one tech, website does not work....does not sound promising.
Old 12-10-2006, 12:06 AM
dochummer's Avatar
I believe the hotshot only includes the heating unit, that's why you have to prime it before use, or else you burn it out. I just pulled my old one out and put a new one in - straight swap of the heating unit...still doesn't work. When I pulled the old unit, it still had tons of washer fluid in it, so I don't believe there's a reason to have to prime it all the time. I've checked fuses and they look ok. Swapped the switch and still no luck....
I'm really enjoying my wife's LR3's heated windshield....
'03 H2
Old 12-10-2006, 01:58 AM
I guess you like the LR3? They seem very nice. I'd probably like the heated windshi... I mean "windscreen" since we're talking about an LR, until it had to be replaced from stone damage... I got away with an H2 windshield for only $225.
Old 12-11-2006, 02:33 AM
dochummer's Avatar
Yeah, that's the only thing that sucks about it...I've heard it's about $1000 for a replacement...
'03 H2
Old 12-11-2006, 04:33 AM
H3PAC's Avatar
H3PAC H3PAC is offline
I like the heated windshield idea. Very cool (no pun intended). It's rare that you have to replace one, but if you do, most replacements can be covered by insurance.
The manufacturer of this system absolutely guarantees that no ice will accumulate on the windshield...ever!
Old 12-11-2006, 11:51 AM
That's all? A HUD windshield replacement on a Corvette was over $1500, and for a GP with a HUD, it was $1100.00.
Old 12-11-2006, 04:09 PM
Boar-Ral Boar-Ral is offline
Boar-Ral is an unknown quantity at this point
Here is another alternative if you live in Canada. They might ship to the U.S. too, but I am not certain.
Old 10-17-2007, 06:06 PM
BTT- Winter's around the corner!!!!! Anymore installations? I don;t think anyone has posted pics of thier installation yet???
Old 10-18-2007, 09:04 PM
dochummer's Avatar
Mine stopped working a while ago. I played with it a little, and actually replaced it with another that was sitting in my garage. Still doesn't work. Not sure what's going on...haven't had the time to look at it again either.
'03 H2
Old 11-27-2007, 07:29 AM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Hey Doc,
I'm pretty sure I know why your Hot Shot isn't working.
If I recall correctly my Hot Shot was haveing the same problem as yours. I called Webasto and they couldn't figure it out so they sent me a new unit but I still had the same problem. Then it hit me
It was a bad ground. I moved teh ground to a solid ground and that solved the problem. It works perfect since last winter.
I did a write up on the Hot Shot install but I can't locate it. I was able to locate teh write up I did on teh install of the fix kit which is needed for H2's
if anyone needs it here ya go:
http://elcova.com/eve/forums/a/tpc/f...241#4141080241
Old 10-29-2008, 03:11 AM
Dan D 2's Avatar
Dan D 2 Dan D 2 is offline
Dan D 2 is on a distinguished road
OK guys....need some help here. Was going to install a HotShots unit before the snow flies and while doing some research, found out that due to a MAJOR recall on GM vehicle, Microheat, the maker of HotShots has filed for bankruptcy. E-bay has one but in lieue of the recall (units catch fire) I'm reluctant to purchase one.
Anybody know of another manufacture for heated windshield washer fluid. I tried the link on here for Canadian Tire but can't seem to find a system on their site...I'll continue to look.
As an FYI, I'm looking for one for my H2.
