Old 12-03-2006, 08:33 AM
TuxifieD TuxifieD is offline
TuxifieD is off the scale
Default anyone hummer ever just not start up?
I was at a party tonight, went out to my car, turned the key everything inside turns on, music starts playn, turn to start it up... NOPE.. wont start up doesnt even make a sound will not turn on... anyone ever have this happen? Im going to have to tow it to the hummer dealership in the morning and Im scared for my baby.....I think im going to have to extend my warranty with this beast
http://www.sourceindustries.net
BF2 hacks, CS hacks, CSS Hacks, Battlefield 2 Hacks, We have all the hacks for any online game, come check us out.
Old 12-03-2006, 08:42 AM
Default Re: anyone hummer ever just not start up?
Sounds like an ignition switch.
Old 12-03-2006, 01:26 PM
JetEyeNite JetEyeNite is offline
JetEyeNite is off the scale
Question Re: anyone hummer ever just not start up?
It happned to me once... I am not sure why but I was able to start the engine using my remote starter. I then turned off the engine and restarted w/ my key again. ??? That was about 4 months ago. Haven't seen that problem again.
04 Pewter Lux
Old 12-03-2006, 04:05 PM
Screeper's Avatar
Screeper Screeper is offline
Screeper is an unknown quantity at this point
My friends H2 just had its starter replaced after the same issue. The truck had 20,000 miles. Starter motors just go bad sometimes.
Old 12-03-2006, 04:16 PM
Sometimes, even if you don't hear a click, it could be the starter if everything electrical is working.
I'm calling starter, starter solenoid or ignition switch- prolly not a major repair.
Old 12-03-2006, 04:40 PM
GLBLWARMR's Avatar
Sometimes it is something just as easy as you did't get it fully in park. This will do the same thing. Enusre the shifter is fully in park then try again. Also you can try to start it in neutral.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
Old 12-03-2006, 05:50 PM
I'm calling it after the party was truck in park or neutral and did you use right key and did you shift to drive after motor was running. And were your shorts on right this morning or did you get home without any and are you Blonde. Hope you had fun. Regards The Rebel
H2 REBEL lennyrebel
Old 12-03-2006, 06:07 PM
Yes, my starter went out. I stopped to put fuel in, and it never started again. TowD!
Old 12-03-2006, 06:27 PM
That's what I was thinking.
Or he was drunk.
Or BOTH!!!
Old 12-03-2006, 07:16 PM
lol was not drunk, I dont drink ... and since im under warranty do I get free road side assistance so that they will tow me back to the hummer dealership for free?
Old 12-04-2006, 03:12 AM
orlasttoy's Avatar
orlasttoy orlasttoy is offline
orlasttoy is off the scale
happened to me...it was my remote starter that shorted out. check that if u got one.
Old 12-04-2006, 04:42 AM
H2bill H2bill is offline
H2bill is on a distinguished road
I would think the answer to that would be YES.
Old 12-04-2006, 07:22 AM
If you don't drink Why did you go to the party? I'm stickin with you put it in drive and then tried to start it and your Blonde and you did go home with no underware. Me think you protest to much. The Reb
H2 REBEL lennyrebel
Old 12-04-2006, 09:32 PM
mdoyle mdoyle is offline
mdoyle is on a distinguished road
Here's an old trick that might save you when the starter "dies". The DC motor has divisions in the communtator that sometimes go bad resulting in a dead spot.
If you bang on the starter with a tire iron while turning the key (takes two people) you can usually get it past the dead spot and start the engine.
I realize this sounds crazy but it works. Of course you'll still need to replace that starter but at least you won't be stranded.
Old 12-06-2006, 01:28 AM
Rene S. Nielsen Rene S. Nielsen is offline
Rene S. Nielsen is off the scale
I just had this problem.
When i came out to get the car it wouldn't start, messed around with it for a complete day, and nothing woorked, the next day no problem. Then 10 days later, I just drove to the otherside off my house, and shut it off, then it wouldn't start, left it until the next day, started without a problem.
Had the ignition key exchanged, there hanv't been a problem since.
If you get stuck i town with this problem, just turn the key to ignition, and short the starter. You have access to the stater just over/behinf you right front wheel, there is not a lot of room, but it can be done.
Best regards
Rene
Old 12-10-2006, 06:58 AM
Where was the party at? I just saw a pair of undershorts going down the Detroit River and I thought of you and your missing shorts and hummer that wouldn't start in Drive . Trying to help, The Rebel
H2 REBEL lennyrebel
Old 12-14-2006, 03:25 AM
IBHUMIN's Avatar
IBHUMIN IBHUMIN is offline
IBHUMIN is on a distinguished road
I had my ignition switch go bad twice this year! First it started where I had no power. It started and drove but the engine would ram but give me nothing. Then finally it died. Had to have it towed to dealership. This was back in February. It just happened again about three weeks ago. I did get to drive it to dealership this time since I realized what it was right away. I don't understand why it keeps happening though. Any suggestions??
Teesh Giese
2005 WHITE H2 SUT. LOTS OF BLING AND DAMN PROUD OF IT!!
1999 HARLEY SPORTSTER ( MAROON )
Old 12-14-2006, 06:39 AM
Nope not yet (H3).
S.
Old 12-15-2006, 01:53 PM
The Transmission is shifted electrically with solenoids. When the ignition switch goes bad it doesn't power up the transmission fuse and the transmission defaults into a second gear start.
Well, there was a TSB out on a particular ignition switch- maybe someone else has details about it. But since you have had two- I don't know. It seems to be a common problem. It could be the way it is seated and daily driving causes things to disconnect, drain battery power or become frayed in some way.
Anyway, the ignition switch and shift solenoids are connected.
Old 12-17-2006, 09:29 PM
partsguy partsguy is offline
Klaus, why are you posting as CP???????????Do something wrong
