11-18-2004, 04:36 PM
Well, my H2 spent three nights on a test unit to see if any modules "woke up" and drained my battery. My HVAC module woke up once but did not drain my battery. Dealer is going to replace just in case...
It appears that H2's may have modules that can wake up and put a drain on batteries. Further, they can wake up and get "stuck on"...or they can get stuck when you stop the engine. No rhyme or reason either....
The GM spec says they should shut down w/in 25 minutes after shutting off engine.
So...GM and I can chase this problem for ever. I see it as a weakness of the design and NOT very reliable.
So I may be leaning to a dual battery set up.
Drty, I spoke with Wrangler NW and they say the install is straight forward. Have you had any problems???
Can I do the following???: Run both batteries when driving around to make sure they both stay charged. Then, when I park, shut off one battery as a reserve in case a module wakes up and drains battery "A"??? Once I get in, try to start on single battery...if dead, switch in second battery??
11-18-2004, 09:15 PM
You could definately do that you just need a battery switch. It is a dial and you turn it from battery A to B to BOTH or to OFF. These are installed in most fire trucks and emergencey vehicles and most boats(that have a dual battery setup) If you leave it on both while driving it will charge both batteries then switch to battery A or B when turned off.
11-18-2004, 10:13 PM
You could also get a "Battery Buddy" or something like it that will shut everything down if the current gets to low, then flip a switch for the reserve to start the truck. I have been thinking of getting one, it would be alot cheaper also.
(05 White SUT)
11-19-2004, 01:01 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Orbyog:
You could also get a "Battery Buddy" or something like it that will shut everything down if the current gets to low, then flip a switch for the reserve to start the truck. I have been thinking of getting one, it would be alot cheaper also. <HR></BLOCKQUOTE>
Good idea but I also have a winch. The dual set up would also help in that area as well.
11-19-2004, 04:51 PM
Had a similar problem, turned out to be a Very corroded Positive battery cable, along with a bad battery.
11-19-2004, 05:16 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Big Z:
Had a similar problem, turned out to be a Very corroded Positive battery cable, along with a bad battery.  <HR></BLOCKQUOTE>
Cable is fine...two batteries killed (OEM and yellow top optima)
12-07-2004, 02:39 AM
where do you fit a second battery. i have wanted to do a dual setup for some time. winching long pulls with the ignition off can really drain the battery quickly. does anyone have a procedure for doing this... or at least a spot.
unaslob
12-07-2004, 02:58 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by unaslob:
unaslob <HR></BLOCKQUOTE>Winching long pulls up a hill with the engine running will drain the battery quickly. I had a brief thought of putting the second over on the passenger side fender in place of the radiator reservoir. Maybe moving the reservoir back further on the fender with some kind of custom flange mount and an extended hose.
I haven't done anything else but have that thought though. I am not even sure if it is possible, but my thinking was one could get a battery mount and put one in the same place on the opposite fender.
12-07-2004, 06:00 AM
Patriot,
I love my dual battery set up. I did have a slight problem with one of the batteries, but Wrangler replaced it. they're dry cell batteries and some how one of them vented. The Odyssey battery rep had never seen anything like it.
Anyway, I highly recommend the set up.
12-07-2004, 08:03 PM
that is a nice setup.. I never thought of actually getting 2 smaller ones but with more power. i have been envisioning of putting a second one of similar dimensions...
unaslob
12-07-2004, 08:46 PM
I want the extra capacity along with the benefits of a "backup" battery and not being sure of how much extra capacity the smaller batteries have, I have only been looking at a setup where I can install two full sized optimas. Otherwise the Wrangler setup is perfect, but I have been too lazy to see what kind of capacity difference there might exist, plus I have a relative new optima already.
12-07-2004, 10:21 PM
i agree. what about the possibility of placing a battery in the rear of the truck... there is plenty of room under the rear for all kinds of stuff... I have an airtank back there already and am think of putting another one in for more air capacity.
unaslob
12-08-2004, 12:08 AM
I have thought about the back. I just worry about running such a heavy guage all the way to the back and it somehow short and start welding **** to the frame. I have the rear air and looked and there is definitely a place to put an optima back there because you can mount them upside down or sideways if needed.
Got any pics of your tank setup and where the disconnects are? I have been thinking about adding a compressor with a tank back there so you have true air and not the puffer that's used for the springs.
12-08-2004, 12:39 AM
i posted that stuff before but couldnt find it with a search. i recently blew the airline running from the compressor to the tank.
gave me a chance to do some new things... but here are the pics of the tank and the quick-connects. i replaced the quick connects with the same ones plows use. they have rubber caps to keep the dirt out. sand, dirt gummed up mine rendering them useless. plus hadley came out with some rubber mounts and socks to silence the compressor which used to be pretty loud... now runs silent. I also put a switch in the cab to turn the thing off for when I dont want it to run.
unaslob
unaslob
12-08-2004, 12:42 AM
unaslob
12-08-2004, 12:46 AM
front
unaslob
12-08-2004, 02:40 AM
I thought I remember someone posting something like this before didn't realize it was you. I didn't really look back to see but I remember it now. Your tank is where my stock compressor is and I am thinking of putting a tank like that along the outside of the frame on the passenger side.
I also was thinking of popping a hole in the metal front and rear bumpers to have the pop-ins located there.
