01-12-2007, 09:58 AM
Re: MOAB RUN 2K7
Just be careful you don't violate the Sand filter regulations if applicable around residential areas..
If so, this is always handy to know. I'm writting off the top of my head so forgive me for the spelling mistakes.
a) General. Buried sand filters may be used, provided the effluent is discharged in accordance with the requirements of Section 905.110.
b) Size. Buried sand filters shall be sized as follows:
1) Residential. The sand filter surface area for residential property shall be 200 square feet per bedroom. Where a sand filter is used in conjunction with an approved aerobic treatment plant, the surface area of the sand filter may be reduced by 50 percent.
2) Non-Residential. All of the following shall be met when a buried sand filter is to be installed on non-residential property.
A) The surface area of the sand filter shall be designed for one square foot per gallon per day for waste with an influent Biochemical Oxygen Demand (BOD) not to exceed 300 parts per million (ppm).
B) A sand filter with flows of 801 gallons or more per day shall have the effluent distributed into the sand filter by a pressure dosing system designed according to subsection (l) of this Section.
C) The sand filter shall be dosed 4 times per day with equal flows not to exceed the design capacity of the filter.
c) A single individual sand filter shall be used to treat flows from a wastewater source. Splitting flows prior to treatment or the use of multiple sand filters shall be prohibited unless subsurface disposal of the effluent is used. Where allowed, splitting of flows shall be done by pumps.
d) Minimum Size. The minimum size buried sand filter shall be designed to treat at least 100 gallons of waste per day.
e) Sand Filter Media. The depth of filter media shall be a minimum of 24 inches. The sand shall have an effective size of 0.5 to 2.0 millimeters, and a uniformity coefficient of less than 3.5. It shall be clean and free of clay and silt.
f) Alternate Media. Other filter media may be used in a subsurface filter provided it meets the criteria of subsection (e) of this Section and complies with the following requirements.
1) Is chemically and biologically inert.
2) Will support biological growth.
3) Has a hardness equivalent to, or greater than, that of sand.
g) Filter Media Cover. The filter media shall be covered with a minimum of 10 inches of clean coarse gravel or clean stone which is free of mud, silt or clay, ranging in size from 3/4 to 2 1/2 inches in diameter. The gravel or stone shall be covered with straw, untreated building paper, or other permeable material prior to backfilling. A minimum of 12 inches earth cover shall be provided. (See Appendix A: Illustration N of this Part.)
h) Distribution and Collection Lines. The distribution and collection lines shall conform to the requirements for distribution lines as given in Section 905.60(b)(2). The distribution lines shall be level, shall be located 18 inches from sidewalls, and shall be spaced on 3 foot centers. There shall be solid pipe to the filter media. The collection lines shall have a slope of 6 inches per 100 feet and one collection line shall be provided for each 10 feet of width or fraction thereof. The upper end of the collection line shall be capped.
i) Bedding Material. The bedding material for the collection lines shall be placed as shown in Appendix A: Illustration N of this Part, shall be clean gravel or clean stone which is free of mud, silt or clay. The coarse gravel shall range in size from 3/4 to 2 1/2 inches in diameter and pea gravel shall range from 1/8 to 3/8 inches in diameter. A minimum of 2 inches of coarse gravel shall be placed on the excavation before placement of the collection lines.
j) Venting. A minimum of one vent shall be placed on the downstream end of the distribution lines as shown in Appendix A: Illustration N of this Part. These vents shall be placed as close as possible to the corners on the downstream distribution lines. The vents shall extend above the ground surface and be screened with 1/4 inch mesh screen or equivalent.
01-12-2007, 05:40 PM
Re: MOAB RUN 2K7
01-12-2007, 08:42 PM
Re: MOAB RUN 2K7
Remember where you're getting rails from.
Please please please get her some upgraded tierods too.
01-13-2007, 12:29 AM
Re: MOAB RUN 2K7
Still plan on going. Anyone else using I-70 West just let me know and we'll hook up for the drive. Tho I may not be in a Hummer....
I'm in. I take it you plan on stopping in KC for the night again? Does this mean we'll see western Kansas go by at something faster than 68mph???
'04 H2
'07 Vette
01-13-2007, 12:54 AM
Re: MOAB RUN 2K7
Anybody have any recommendations on Motels?
2006 H3 Superior Blue, Adventure + Lux Pkg, Automatic, Sunroof, GPS, Rocker Protection, Black Brush Guard, Roof-mounted off road lamps, Trailer package, Underbody Protection, ROLA Roof Rack, and now Toyo 35's!
01-13-2007, 01:29 AM
Re: MOAB RUN 2K7
In Moab itself or on the way there???
'04 H2
'07 Vette
01-13-2007, 01:36 AM
Re: MOAB RUN 2K7
Moab itself.... I'll probably be stopping for a few days with a friend in Coaldale CO. before heading off to Moab Monday.
Thanks!
01-13-2007, 05:20 AM
Re: MOAB RUN 2K7
the Gonzo is a very nice place. Ramada is right next door and is adequate.
01-13-2007, 08:29 AM
Re: MOAB RUN 2K7
Ramada is a crack house.
I remember visiting PhilD and Seth's room, it smelled of raunchy sex and day old cum.
......Sorry, I'm very drunk right now partying with my wifey's 5 Japanese milfs over for a sleep over drunkfest. My upgrades are off line at the moment.
01-13-2007, 10:31 AM
Re: MOAB RUN 2K7
2 words......PICS NOW!!!!
'04 H2
'07 Vette
01-13-2007, 06:12 PM
Re: MOAB RUN 2K7
I thought some were also renting houses???? Humbebe? info? please?
01-13-2007, 06:25 PM
Re: MOAB RUN 2K7
I won't be renting....I have a place to stay...
But here are some llinks for those that would like to:
Here is where we stayed the first time
http://www.vrbo.com/55868
But we much preferred this one:
http://www.coyoterunmoab.com/
April is the less expensive time to go, so try not to spend/pay more than $250.00 per night.
01-13-2007, 06:48 PM
Re: MOAB RUN 2K7
ATTENTION DRTY: SPAMMER POST!
01-13-2007, 07:14 PM
Re: MOAB RUN 2K7
Me??? Ask Ken.
01-13-2007, 07:19 PM
Re: MOAB RUN 2K7
Me??? Ask Ken.
I tried, but he's out getting his nails done.
01-13-2007, 08:22 PM
Re: MOAB RUN 2K7
01-13-2007, 08:25 PM
Re: MOAB RUN 2K7
Thanks for the info HummBebe!
I didn't mean to get you in trouble!!
01-13-2007, 08:46 PM
Re: MOAB RUN 2K7
I'm sure he feels used. We all do.
01-13-2007, 08:47 PM
Re: MOAB RUN 2K7
No worries, she's always in trouble.
BTW, The Coyote Run place she linked to was very nice.
01-13-2007, 08:51 PM
Re: MOAB RUN 2K7
x2
