Old 02-06-2007, 04:06 PM
Xotik H3 Xotik H3 is offline
Xotik H3 is on a distinguished road
Default Newby thread Highjacked - Lets talk about filters!
I am not a K&N pusher, but use the product. There are a lot of people on here who dislike them. So here is the place to discuss.
From the K&N site,
http://www.knfilters.com/testmethod.htm
http://www.knfilters.com/efficiency_testing.htm
Other opinions
http://www.duramax-diesel.com/spicer/index.htm
My experience,
1999 Camaro - 90,000 miles, no issues K&N on since new.
2003 ZO6 Magnacharged - No issue's with K&N kit 15,000 miles (sold)
2002 Jeep Rubicon - No issue's 50,000 miles K&N and Gibson Exhaust Nice power gains with the two (Sold)
2004 Infinity FX35 - No issues K&N 75,000 miles (Sold)
2005 Big Dog Chopper - No issue's, K&N added per dealer request, and no I did not purchase it from them.
Old 02-06-2007, 08:16 PM
Default Re: Newby thread Highjacked - Lets talk about filters!
I liked that independent report--K&N plugged up 3x faster and passes 7x more dirt so everything comes with a price. Good Info Regards The Rebel
H2 REBEL lennyrebel
Old 02-07-2007, 12:04 AM
No thanks, any puny increase in power is offset by suspect filtration and unpleasant intake noise.
Old 02-07-2007, 12:47 AM
Viet Nam Vette's Avatar
And A Motor Full Of Dirt...
Old 02-07-2007, 02:06 AM
Huck BB62's Avatar
It does make sense that the K&N lets more dirt through. An air filter traps dirt with media. The air flow is restricted by the media. The only way to trap dirt is to have smaller openings. To have better air flow, the openings either have to be larger or their has to be a lot more surface area, more pleats. Since the K&N obviously doesn't have more surface area of media, it must have larger openings. This would explain the enhanced flow when clean. BUT the dirt IS attracted to the oil. I do know from our testing (we have air filters three stories tall) that as the filters clog up, they become better at filtration. So about the time K&N filters become as efficient as the dry filters, they also lose their advantage for air flow.
If you're not going to keep your vehicle a long time, go for the K&N, it does flow better. Keep it clean and enjoy the increase, if you believe the hype that is.
A few issues back in the Diesel Power Magazine, they tested ten of the intakes. High dollar to low, they made zero difference.
The intakes are a waste of money in my opinion.
Old 02-07-2007, 08:46 AM
kma kma is offline
kma is on a distinguished road
Have you actually tried an after market intake on an h3? There is definitely a noticeable difference in power including holding speeds and downshifting.
There is another question as to air filters though and that is if the engine need more air. I think the H3 performs better with the additional air flow after switching back and forth between a K n N and the OEM filter.
Also, I read somewhere(have to look around) that oil gauze filters pass like 99% of the dirt in the first 3% of the filter life. So I wouldn't install an oil filter right before going off-roding in the desert. On a recent trip I replaced my OEM Filter for the trail.
Old 02-07-2007, 04:02 PM
H3.007 H3.007 is offline
Sorry guys but-
Mine picks up much more speed, much quicker...
But agreeably, it is loud in the high end.
I wonder how many vehicles were tested during those tests. One vehicle plus ten filters doesn't equivocate to a proper research sample in my book. Ten vehicles with ten different filters applied to each vehicle - now we are getting somewhere....
Old 02-07-2007, 06:39 PM
I drove the dealer's H3 with the SMA intake, all I could feel is more noise. Measuring acceleration differences is not the same as the illusion of more speed/perception based on noise. So far, haven't seen any facts to support the intakes and improved performance on H3.
Old 02-07-2007, 06:59 PM
bparker's Avatar
bparker bparker is offline
K&N all the way here too on all my race cars, Corvettes and Motorcycles.
Consiracy Theories that you have mounds of dirt in your motor from these filters are rubbish.
All and any tiny pieces of "dust" that makes it into the cylinder chamber is incenerated upon detonation OR if not it is passed out of the motor through the exhaust port on the cylinder head into the exhaust and then burned up again at the cyatilic converter.
Also if for some other reason it is left behind it is caught by the oil and then filtered out by the oil filter..
http://www.tahoeforum.com
http://www.motoforum.com
Old 02-07-2007, 07:13 PM
In this case, more noise is the byproduct of more flow.
Really though, when it comes down to it, I would not think it would be easy to "feel" 5 HP. Where you would notice the improvement is down low in the RPM band where the extra flow will improve the efficiency adding torque.
On my Wranglers stock engine, 5 speed, 33 inch tires.
- 5 gear was not usable at 1500 RPM -
- K&N added, you could use 5th at 1500, not usable at 1300 RPM.
- Added Gibson exhaust you could use at 1300, not usable at 1100 RPM.
What does that mean, I improved the engines ability to get more air, more fully filling the combustion chamber, ADDING TORQUE, then more fully expelling the exhaust, adding MORE TORQUE.
I could not "feel" the difference and could not tell you if it made a zero to 60 run difference. I am sure it did but only in a 10th of a second or two. In the higher RPM band is where you will always see the best gains, but really, who wants to twist the I5 to 5500 RPM.
An engine is like an air pump, the easier you can make it pull air in, or expel air the more efficient it is, which means more HP and more torque. In the H3 you will notice it under load from towing, and perhaps in 1 to 2 additional MPG.
Please do not confuse my statements with engine management - fuel or spark curves, ect. This is a basic look.
Old 02-07-2007, 07:30 PM
Who said anything about noise correlating with performance?
Regarding the noise, I thought it might have had to do with the lack of the resonance chamber being present in the application. But hell, it is only loud in the high RPMs, where I am rarely at, and the neighborhood kids love it when I kick it in
I do not, however, believe it has saved me any fuel. But then again, I constantly drive it likes it is stolen. I suppose GM conducted their MPG tests with no extra weight and at an exact, average speed limit...
Regarding the comment on the lack of studies proving it, where are the valid and reliable studies proving that the kits do not work and do indeed damage engines?
Like I said above, one vehicle with ten filters changed in and out is not a valid nor reliable scientific study by any means.... Further, wasn't that on a diesal engine?
Old 02-07-2007, 07:39 PM
stagger_lee's Avatar
White Collar Hippie
'06 Luxury Adventure
'99 Toyota 4runner 4x4
'71 FJ40
Old 02-07-2007, 08:03 PM
Now if you really don't mind noise and contamination in your intake etc. move right up and get a marine flame arrestor;you'll really decrease filter drag and as long as your in a clean enviroment you'll up the horsepower and only have to swish arrestor in varsol every couple years if you want.The Rebel
H2 REBEL lennyrebel
Old 02-07-2007, 09:11 PM
A lot of "believing" about K&N performance and mpg benefits, but no facts supporting any substantial gains on the H3. No thanks.
Old 02-07-2007, 09:50 PM
*Sigh*
As I already said above:
Old 02-07-2007, 10:19 PM
All is right with world... go drive your H3.
Old 02-07-2007, 10:48 PM
bparker's Avatar
No, I am not so anal about "noise" I bought an off road truck not a lexus sedan - further more I use the radio, listen to music which makes the "noise" irrelavent. If you want a car to be so quiet I think one should look for a lux sedan.
My thoughts having suped up sports cars and motorcycles all of my life I find to complain about something as a tiny bit more "noise" made by an air intake is like complaining about a CD changer making noise while it changes CDs.
Old 02-08-2007, 02:09 AM
I agree that the H3 is a truck and I would expect it to drive and sound like a truck (not like a car). In fact I have the Corsa dual outlet system on my H3. Power increase is so small that it can barely be felt, but it looks cool and sounds like a DOHC straight 6 at higher revs. Yea it's a bit louder than the pitch quiet stock exhaust.
Old 02-08-2007, 03:30 AM
Huck BB62's Avatar
Well, they did use a dyno. Call me nutty, but that carry's a little weight compared to the "it felt faster" point of view.
Yeah, the tests are on a diesel. I've yet to see where K&N builds their filter any different for any application from a Toyota Tercel up to a Viper.
I can't figure out for the life of me why, after reviewing the above website that tests K&N filters, someone would choose to abuse their engine that way unless they figured on selling it instead of keeping it. The test is a damnation of their media, not of the intake system, and beyond that the other test that I referenced is a test of SEVERAL systems. Today's intakes are damned well engineered and don't need, or benefit, from upgrades or modifications with a stock engine. Even at that, I will never believe the K&N claims again unless I see a dyno test, period.
The H3 intake is already a cold air system. Looking at it, and the displacement of the I-5, it's hard to see any gains to be made by spending money on the K&N or any other intake. The stock filter is very large for the engine's displacement. As others have said on here, it's an air pump. If the engine isn't capable of moving more air than the stock filter and intake are capable of flowing without restriction, then there's no benefit to spending the money on the "upgrade".
Old 02-08-2007, 09:59 AM
kma kma is offline
Hello all. I can feel the increase in power.
