  #41
Old 03-07-2006, 12:03 AM
jp's-h3 jp's-h3 is offline
Yes, it is pretty clean! that is because I preasure washed the engine before the install!
thanks!
Old 03-07-2006, 12:48 AM
fourfourto's Avatar
jp's-h3 Did you put on the twist on air filter (does it fit)?.
Also do you have pics yet of the lines?
I will have info on my fitting and lines by the end of the week .I hope to install sunday.
Old 03-07-2006, 01:02 AM
Filter does fit, It is tight though.
I've done a few other add-on's. I'll post pics asap!
Old 03-07-2006, 10:54 PM
Here are the rest of the pics from the compressor install.
The first pic is w/ the air hose installed.
(notice that it sit's too high to close the hood) I'm looking to see if I can find a 90 degree coupler fitting, this will lower the height of the hose when installed and allow for room to shut the hood w/o removing.
also notice the air filter (just below and to the right of the air hose fitting).
make sure to leave enough room to remove the air filter for cleaning.
Old 03-07-2006, 10:57 PM
This pic show's where I have the air hose running from the engine compartment to the frame rail.
Old 03-07-2006, 11:08 PM
Here is a pic of the boot that I put on the coupler when not in use.This will protect it from dirt, water, ect.
also another shot of the filter.
Old 03-07-2006, 11:18 PM
I was'nt able to get a good shot of where the air hose runs along the top of the frame rail(drivers side) but, here is a pic of where it is accessable. at this point I have'nt attached it, and may not attach it! I used a short length of pipe insulation for protection. notice at the tip of the male fitting, I've used a pop piug to protect it from mud, ect.
Old 03-07-2006, 11:38 PM
And last but not least!
A pic of the coil air hose installed.
This is a great location! it makes airing up all four tires(or any of my daughters inflatable toy's) a snap!
I hope this install will help all of you that would like the conveinence of a hard mounted, on-board air compressor installed on your rig!
Remember! This install is pretty easy and the compressor used in this install is a MASTER FLOW MF-1050.
Using a different compressor for this particular installation could alter these instructions on the procedure significantly.
I would also like to add that the MASTER FLOW MF-1050 is a great little unit and, works very well. From airing-up large tires, to small inflatables, bicycle or motorcycle tires. For the price it can't be beat! "GOOD LUCK" and AIR-ON!!
Old 03-08-2006, 12:52 AM
fourfourto's Avatar
jp's-h3 Looks great Ill let you know how I make out.
Old 03-08-2006, 01:18 AM
AWESOME! That turned out very nice and clean jp!
Old 03-08-2006, 02:21 AM
k9tim
That looks great! You just added another project to my list.
Nice job man, very nice!
Old 03-08-2006, 04:13 AM
Thanks fella's!
Now I need to find another project for my H3!
Enjoy!
Old 03-08-2006, 04:15 AM
Hey fourfourto!
let me know if you come across a 90 degree fitting! Thanks!
Old 03-08-2006, 12:08 PM
fourfourto's Avatar
JP I told my brother to get a extra 90% fitting ,but male end might not fit your female end(Ill try to get a extra female end and maybee you can work it out).Hes hooking me up with hard hose(DOT tractor trailer air brake hose) so it might be different I will have it by saturday Ill let you know .You can PM me with your address and I can send you it, if you cant find a 90% for yours by then.
Old 03-08-2006, 02:18 PM
ETD's Avatar
ETD ETD is offline
ETD is an unknown quantity at this point
Wow.
Nicely done, indeed. I would love to know how the set up holds during and after off-roading. Thanks jp's-h3.
Old 03-08-2006, 02:34 PM
Thanks fourfourto, you da man!
And on another note, For all of you folks that have done or are going to do this compressor installation. Make sure the engine is running when using the compressor. This gives the compressor much better "Compression" thus, better air flow!
Old 03-09-2006, 01:26 AM
k9tim
Man that install looks sweet! The fact that the compressor shroud is red makes it even better.
Top notch job and a great idea running the hose down to the frame. Very nice!
Like the others said- another project to put on the list!
Old 03-09-2006, 05:04 AM
MarK M's Avatar
MarK M MarK M is offline
well done!
Old 03-09-2006, 09:55 PM
You could easily take the shroud off and paint it to match any H3! The MF-1050 does come in red only!
Old 03-09-2006, 10:05 PM
fourfourto's Avatar
I like a little <span class="ev_code_RED">Red</span> under my hood.
I talked to my brother .I wont see him till saturday after work. I think Im getting Quick relese fittings at compressor (not the same as air hose fittings) It will attach to hard hose .The fittings and hose are what the tractor trailers use, I will use original male(from compressor)at the frame and use original female on coil hose .
I told him to get me extra set of fittings if posible ,I can always send you a leftover piece of hard hose(Im getting 8 feet) You might be able to put the hard inside your ruber hose and clamp it.Ill list pics this weekend of what I get .
