Old 02-19-2007, 05:03 PM
Christian GM Christian GM is offline
Christian GM is off the scale
Default 39" tires under the 2006 H2 SUT
Hi guys!
a customer have buy locally the 39" tires of a Merceds Unimog, and want to fit with 20" wheels under his 2006 SUT.
Did you have any suggest about suspension modify, shocks, transmission, ring & pinion kit, with aslo supplier/manifacturer suggest???
thanks in advance to all!
Old 02-19-2007, 05:16 PM
Ernie Italy is off the scale
Default Re: 39" tires under the 2006 H2 SUT
Lo sfascia.... come quello che ha fuso con il Turbocharger in zona Padova....
Dopo aver preso le ruote compra il resto e ci fa un UNIMOG.
Old 02-19-2007, 05:29 PM
Why are you speaking arab ??
Old 02-19-2007, 08:19 PM
Ernie say that 39" make for sure a lot of damage ...
seriously damage and a lot of money to fix.
I'm sure that 37" fits w/o problem, ins't it?
But how about 39"???
I believe there is someone in the USA already do it...
Old 02-20-2007, 05:48 AM
BIG LIFT KIT! 10"
Old 02-20-2007, 05:55 AM
You're gonna do it aren't you Rocks???
Old 02-20-2007, 06:12 AM
Here is a 10 to 12 inch lift kit from Cognito Motorsports. I know a fellow that owns the 4X4 shop here and he runs this lift on his full size Heavy Duty GM truck.
When I looked at this kit 3 years ago, they didn't offer it in 4" but now I see they have one.
Here's the link : http://www.cognitomotorsports.com/store/Hummer_H2.html
Old 02-20-2007, 07:30 PM
BUT...
if the 37" fits only raising a little the standard torsion bar...
why for 39" I need a 10" lift kit???
Is not enaught a 2" torsion key kit (cheaper) or at least a 4" susp lift kit (expansive...)
However how about axles and ring & pinion kit???
Let me know, thanks
Old 02-21-2007, 12:35 AM
Okay, what do you want it to look like? Do you want it to look like you put tires on that are too big? Unimog tires arent' exactly narrow. Search on here for pictures of lifted H2's.
You can crank up the torsion bars so it rides higher, but the tires will still probably rub when you turn the wheel to full lock.
I suggested a lift by Cognito.
IMO, Tires off a unimog aren't exactly stylish or practical for driving on the road.
Old 02-21-2007, 12:55 AM
http://www.elcovaforums.com/forums/s...ht=yellow+lift
the first pic is an H2 on 40" tires lifted 6 inches
Search for 38" or 40" tires. 39 is an odd number to search for but you can try it.
Old 02-21-2007, 10:41 PM
thanks to all!!!
Old 02-22-2007, 01:30 AM
aj_111_78 aj_111_78 is offline
aj_111_78 is on a distinguished road
super lifts has a 7.7 inch lift that 39 inch tires will fit under make sure you upgrade steering and drive train also
Old 02-23-2007, 06:41 PM
KONG KONG is offline
KONG is on a distinguished road
you might want to check the speed rating on those unimog tires too because I think the rating on those are like 55-60 mph. not very fast and not safe if you plan on highway driving.
Old 02-23-2007, 09:24 PM
CONRAD II's Avatar
There is no doubt that they are BIG
66' VETTE STINGRAY
07' Z06
Old 05-30-2007, 02:42 AM
peppexcursion peppexcursion is offline
peppexcursion is on a distinguished road
Talking Re: 39" tires under the 2006 H2 SUT
@ CHRISTIAN GM....
What are you doing here men?? I'm so surprised to see you here!
See you in the italian forum.....
I just think that the "39 are too big at all....just for offroad use....but maybe with a Full Throttle Suspension lift kit...can be possible with no after damages....
Old 05-30-2007, 04:00 AM
IRA51's Avatar
IRA51 IRA51 is offline
Someone may be pulling a fast one in this post .
A government big enough to
you have.
-- Thomas Jefferson
Old 05-30-2007, 05:49 AM
johndjmix1's Avatar
johndjmix1 johndjmix1 is offline
johndjmix1 is off the scale
Screw just the tires, I want the entire UNIMOG. Those things are excellent!
50-60 on the highway isnt dangerous.....Ill only go 55 max speed in my h2 (18-19 MPG =))).
--John
2006 Hummer H2 Lux Series
www.JohnHasMoreFun.com
1/4 Mile 15.29@91.34mph
Mods:
Warn 9.5 Winch
Old 05-30-2007, 02:14 PM
LOL
