Old 03-02-2007, 07:45 PM
Default Re: When do you change your oil?
I agree with feedback from F5 and NewHummerGuy on the oil monitoring system and I am doing my oil changes at intervals closer to 8000 miles + based on system.
Old 03-02-2007, 08:32 PM
Originally Posted by f5fstop
If people are worried about their oil, and were wondering if the oil still had some life after the change, they can always send a sample off to an independent testing lab and get the results back in a week or two. I have done this many times, even when going on the oil life monitor to the big zero, the oil still had a TBN (total base number) above minimum, and the adaptives were still present.
Old 03-02-2007, 10:11 PM
he is the KIng, Long live the King
Old 03-02-2007, 11:57 PM
whaaaaT whaaaaT is offline
whaaaaT is on a distinguished road
I dont care what the monitor says,I will change the oil with moble one synthetic every 6,000 miles.
I am planning on keeping the H3 for a long time and probobly keep it past 250,000 miles
At 50,000 im planning on changing trans fluid and the rear fluids and will repeat every 50,000.
Also every tire rotation I will clean and add brake lube to the brake pad shims so the brake noise doesnt come back.
250,000 miles at 40 bucks a change for synthetic maybe more. Im just guessing cause firestone is more than that without the coupon. If you change your oil every 6,000 miles for 250,000 you could've bought an engine and a transmission anyway. Plus they will probly be cheaper to get a rebuilt one by then.
This is interesting
Make sure you guys read the 3k mile myth and the dark oil myth on the bottom
http://en.wikipedia.org/wiki/Oil_change#Maintenance
Old 03-03-2007, 12:00 AM
I just have evldave taste it. If it tastes like oil still i leave it in there till evldave says to take it out. He takes it right off my dip stick. yummy
Old 03-03-2007, 12:03 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
Originally Posted by whaaaaT
I just taste it. If it taste like oil still i leave it in there till HE says to take it out. yummy
fissed...
Old 03-03-2007, 01:29 AM
thats not what i wrote. Maybe you should read it again
Old 03-04-2007, 05:47 AM
Lex_Ordo
My H3, will be a year old in April. Up to this point I have been changing my oil every three months, regardless.
Now that the first year is almost done, I think the motor is pretty well broken in. I only have around 7600 miles on the truck. I will do one more three month oil change in April, have the air filter and wipers changed out as well.
Then...from April on forward,
The PCM will be the oil change indicator.
Old 03-04-2007, 10:32 PM
This is interesting
Decent article but...
"There are still vehicles that need 3K oil changes, but it's not because the oil goes bad after 3K miles. One example is the Saturn S series. These vehicles have a timing chain system that is very sensitive to clean oil because oil pressure is used as hydraulic fluid to ratchet up the timing chain tensioner. If varnish forms in the timing chain tensioner bore then this system can fail and the chain will become loose and eventually break. Dealers have gone as far as tearing out the normal service schedule (6000 miles) and leaving only the severe service schedule. If an engine is destroyed by a failed timing chain while under warranty, then the dealer will legitimately request evidence of oil changes from the owner. Unfortunately this problem usually won't manifest itself during the warranty period."
True for first two years of the S-series; however, after that there was no big problem with the oil passages and varnishing for lubricating the timing chain. Also, no dealer was able to void a warranty if the customer had the oil changed at 6K. NO dealer can VOID a warranty, only Saturn corp could void a warranty, and we NEVER voided a warranty for changing oil at the recommeneded interval.
Hell, we knew it was a problem, and even cars out of warranty were covered if the customer called, or the dealer called for 'em.
"Instead of making motor oil with the conventional petroleum base, "true" synthetic oil base stocks are artificially synthesized. ("Commercial" synthetic oils are in fact Group III mineral base oils.) "
Mobil 1 and one of the grades of Amsoil are Group IV syntethic; there might be others.
Old 03-05-2007, 03:07 PM
H3.007 H3.007 is offline
Originally Posted by HummBebe
H3.007 = PhD certified nerd
Although not of typical nerd size (6'3", 230 lbs of twice per day worked out bod')
Old 03-05-2007, 10:35 PM
deserth3's Avatar
deserth3 deserth3 is offline
When do I change my oil?
Usualy when I'm at work.
