04-07-2007, 03:59 PM
ITS FINALLY HERE SUBWOOFER STEALTH BY JL AUDIO
Its about time, no pricing yet but my guess is $399.00
First off here is the Link = YOU MUST HAVE THE MONSOON SUBWOOFER.
http://mobile.jlaudio.com/products_s...hp?fit_id=1554
Completely invisible bass upgrade! The compact H3 has been a huge success thanks to its combination of style, utility and substance. Our Stealthbox? for the H3 achieves the same goals by seamlessly integrating into the H3?s hatch without sacrificing any cargo space. The only thing you lose is the weak factory bass. This Stealthbox? houses a JL Audio 10-inch subwoofer in a compact sealed enclosure that installs inside the H3?s driver side hatch trim panel. You can still carry all the gear you want and no one will know it?s in there (until you let them listen to your system).
THE HARD DATA:
Contains one 10W1v2-4 subwoofer in a sealed enclosure. 150 watt power handling. Wired for 4 ohm mono. Replaces factory Monsoon? subwoofer located on the driver?s side behind rear storage panel. If the vehicle is not equipped with the Monsoon? subwoofer system, you must purchase a new driver side rear trim panel from GM parts in order to install the Stealthbox?. Will not fit Hummer H2 or H2 SUT
Stealthbox Color and ordering informationMODELSKU#YEAROEM COLORCOLOR MATCH GRADEWOOFERSHIPPINGSB-GM-HUMRH3/10W1v2/BK 94196 '06-Up All N/A One 10W1v2-4 In Stock
CURRENT HUMMER:
Number# 11  2007 H3x Desert Orange
SOLD BUT NOT FORGOTTON
1995 H1 350 HT GAS Black
2001 H1 Open Top Black
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
2008 H2 Black/Sedona
2009 H3T Alpha Solar Flare
04-07-2007, 05:14 PM
Re: ITS FINALLY HERE SUBWOOFER STEALTH BY JL AUDIO
WOW !!!
I've been holding my breath for that to arrive...
Guess thats why I type blue
04-07-2007, 05:23 PM
What do you do if you have a cubby there ?
04-07-2007, 05:31 PM
If the vehicle is not equipped with the Monsoon? subwoofer system, you must purchase a new driver side rear trim panel from GM parts in order to install the Stealthbox?. Will not fit Hummer H2 or H2 SUT.
New panel = $$$ im sure
It would be cool to add if you dont have the monsoon,It might just fit in the cubby hole.
My eclipse is good but could use heavier bass.
04-07-2007, 05:55 PM
Here are the installation instructions. Not to bad, but a bit lengthy.
DOWNLOAD HERE : http://www.hummercor.com/images/forums/h3jl.pdf
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
04-07-2007, 06:04 PM
WOW !!!
Must of been for only a second then :-)
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
04-07-2007, 06:21 PM
LOL !
04-07-2007, 10:14 PM
This is a great way to get more bass without a box in the cargo space or modifying any rear panels. Does it need it's own amp? Or just plug and play?
04-07-2007, 10:49 PM
these are from teh instructions:
Run speaker wire from the amplifier location to the
Stealthbox® and attach to the terminal.
JL Audio recommends using a high quality amplifier such as the JL Audio a2150.
so based on that i assume you gotta get your own amplifier and mount it remotely. so it doesnt need an amp but it would be better with one. if you dont want an amp looks like plug and play (electronics wise). the mounting seems different or something. still pretty good though, i might make the switch.
04-08-2007, 04:09 PM
If I got this, I would want all new speakers!
Anybody have a price for this yet?
04-16-2007, 03:30 AM
Local JL dealer states this box is $530.00 US. Thats about $150.00 More than I ever expected!!!
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
04-16-2007, 03:51 AM
That sounds a little steep for a sub and a box.  Definitely has been moved down on my wish list.
