05-16-2007, 04:37 AM
Re: Red Ink+Carpet
f5...
I am very disappointed in you. YOU OF ALL PEOPLE did not supply all the info.
1. type of carpet (shag - berber - etc)
2. brand of carpet (mohawk etc)
3. type of fibre the carpet is made from (cotton -nylon - etc)
once i have all your info i will supply the answer
OH
BTW
What brand of pen & ink color ???
05-16-2007, 04:57 AM
Re: Red Ink+Carpet
Try brake cleaner, LPS brand if available works everytime--maybe test in closet first. Regards The Rebel
H2 REBEL lennyrebel
05-16-2007, 06:57 AM
Re: Red Ink+Carpet
05-16-2007, 07:49 AM
Re: Red Ink+Carpet
I would try hydrogen peroxide first ... blotting VERY well after each treatment. Then, use OxyClean for the remaining red. I think between the two, you'll get it out. Don't wait too long. Good luck.
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
05-16-2007, 10:40 AM
Re: Red Ink+Carpet
f5...
OH
BTW
RYD...Want to ask me about cars, handguns, or how to torture someome I will have an answer. However, I have no idea what type of carpet I have other than it is tan.
Pen was a BIC, as I stated earlier, color was RED.
05-16-2007, 12:44 PM
Re: Red Ink+Carpet
05-16-2007, 12:59 PM
Re: Red Ink+Carpet
ONE of the BEST ways is the trigger pull on an empty chamber. Most SANE people can't take that more then 3 times as long as it is included with sleep depervation first through TOTAL silence mixed with times of TOTAL noise inclusion. Sound and silent times must be a minimum of 24 hours...
Also in the top 5 is the painless anal probe. Use a high quality anal probe found in any good porn shop. Not to small nor to large and do use lube. Gentle insertion into the prisioner is important. Before any question begins it must be left in at least 90 minutes. The prisioner must be made immobile and sight and sound deprived. Just the sound of a car battery (or AC setup) shorting (that sizzle and spark sound and smell) works very well
Another is the warm to hot bath. Again sight and sound depervation makes it more effective. Restrain the prisoner in a deep verticle tub of water up to the neck for a minimum of 6 hours (naked) then slowly heat the water. Small air burst from a tube at the bottom every so often once the water reaches 110 to 115 degrees and continuing as the water temp increases works well...
OH
btw
hydrogen peroxide followed by oxi-clean are an excellent suggestion for ink removel from ball-point pens...
05-16-2007, 02:11 PM
Re: Red Ink+Carpet
" Also in the top 5 is the painless anal probe. Use a high quality anal probe found in any good porn shop. Not to small nor to large and do use lube. Gentle insertion into the prisioner is important."
Um......ok RYD. Not sure why you know this one but the words..
Painless....Anal.... and Probe shoudl never be used in same sentence
I'm Gonna crazy you my body
05-16-2007, 02:47 PM
Re: Red Ink+Carpet
Everyone who leaves the Hummer family ends up at their place sooner or later. You know that "guest house" in their backyard? It's actually a chamber of horrors reserved for traitors.
Dang, Thats it, I am never going there...
I am heading over your way later on today, Then over to I-Drive. I will be sure to stop by and check on those pigieons I sent ya.
05-16-2007, 04:02 PM
Re: Red Ink+Carpet
Replace the carpets.
Just a thought.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
05-17-2007, 06:46 PM
Re: Red Ink+Carpet
[b][color=blue]OH
btw
Thanks.
05-17-2007, 07:37 PM
Re: Red Ink+Carpet
I would just piss on it
05-17-2007, 08:33 PM
Re: Red Ink+Carpet
ROFL @ this thread
05-17-2007, 08:50 PM
Re: Red Ink+Carpet
That would get the red out fer sher. Orange isn't as bold a color. Red and yellow = orange, right?
