05-19-2007, 02:11 AM
my rearend
05-19-2007, 02:16 AM
Re: my rearend
You have some seeping out your plug hole
05-19-2007, 04:16 AM
Re: my rearend
Is that Martha Stewarts crackle effects on the back or is your dif cover cracked
05-19-2007, 04:31 AM
Re: my rearend
I'm not sure what's up with that.  I didn't notice it until I took the pic. I just picked up my truck this afternoon after having the rear axle replaced so I'll have to check with them on Monday.
05-19-2007, 04:56 AM
Re: my rearend
why'd you have it replaced? did i miss something? my diff has some of those crack looking things too, i think its juts the casting process and not really a problem, but not sure.
05-19-2007, 06:21 AM
Re: my rearend
Chipped some teeth in the diff - on one of the spider gears I believe. I didn't get to actually see the carnage this time since they had already put the cover back on the old axle and had it packed up ready to ship back.
The tech also said he found lapping compound in the diff. Kinda surprised since I have 36K+ miles. You'd think it would've caused a failure a long time ago. But whatever it takes to get it replaced under warranty with no questions asked.
05-19-2007, 06:46 AM
Re: my rearend
Glad there's no pics.
05-19-2007, 01:00 PM
Re: my rearend
I must say, I am a little dissappointed.
05-19-2007, 01:45 PM
Re: my rearend
JUST FOR YOU...
05-19-2007, 06:23 PM
Re: my rearend
Here's a good one.......
05-20-2007, 12:03 AM
Re: my rearend
Dripping out of the top (fill) hole is usually not a concern. However, dripping out of your lower (drain) hole is a problem,
05-20-2007, 01:02 AM
Re: my rearend
Slap a Depends diaper on there and you're good to go! That should take care of the seepage.
HUMVH3
05-20-2007, 02:17 AM
Re: my rearend
05-21-2007, 05:05 PM
Re: my rearend
Sewie - as one of the few "docs" on here, may I recommend some Preparation H for the cracks and a box of Depends for that leak
05-21-2007, 10:44 PM
Re: my rearend
05-22-2007, 01:51 AM
Re: my rearend
No worrries doc, it was just a case of swamp a$$, 20 hours in the saddle....know what I mean?
05-22-2007, 02:30 AM
Re: my rearend
Bwahahaha!
Well, KY will take care of that there saddle blister!
05-22-2007, 04:25 AM
Re: my rearend
05-22-2007, 06:04 AM
Re: my rearend
you're a dik
how much of that sh1t do you have??? Obsessed much???
