07-11-2007, 01:13 AM
stop calling me out!
well after the millionth person called me out on not having the matching wheel on the back, I finally put the 5th 24" on.
cut some off.
added a stud.
used four 3/4" nuts for a spacers
I like to use all spline-type lugs so they're easier to start down in the seat
ta. da.
07-11-2007, 01:37 AM
Re: stop calling me out!
Nice rear end!!
I like those tires!!!
07-11-2007, 05:21 AM
I not one of the ones that called, however I am doing the same thing at the moment. I am just waiting on the tag/hitch to come in. Thanks alot for the pics....Jamie
07-11-2007, 05:24 AM
Also, did you add the extra stud for pure support? Were 3 not enough? Also, why the 3/4" nut in the back for the spacer, and can the cut be made with a Dremel tool? Thanks....Jamie
07-11-2007, 09:22 AM
the stud is for support, I'm not sure it needs it, but it really wasn't all that hard, so why not? I used a 9/16" bit to open up the little hole for the stud. Then i used a dremel to open it up a little more, then hammered the stud in from the back.
If I hadn't used the spacer, because it has a different backsacing, it would have sat crooked. I guess I used a nut for a spacer because it's better than a stack of washers.
You can eventually cut anything with a dremal, but I used a reciprocating saw to cut off the support. [that mild steel frame cut like butter] As for how much to cut off; put your wheel up there and mark the most you can leave and still put on the center cap. You don't want to try to line up those studs in mid-air, least of all in the rain or mud or hanging off a 1000' cliff or whatever.
My license plate is just zip-tied to the arm for now, still using the factory light, but you'd never know it, cause you'd be blingded.
07-11-2007, 04:48 PM
How are you still using the factory light?
07-11-2007, 08:09 PM
07-11-2007, 08:40 PM
Yea but it makes your butt look fat.
A government big enough to
you have.
-- Thomas Jefferson
07-11-2007, 09:26 PM
you should change your call sign to "Sir mixalot"
07-11-2007, 11:25 PM
Do they make non-low profile tires for 24 inch rims now? Ive had a set of 24s and 26s (both which I sold) and have a set of 22's on there now because 2 years ago that was the largest rim you could get while not having a low profile tire. In that picture that looks like a pretty tough tire, I was always replacing tires a few times a year. A low profile tire cannot handle a hummer.
My cars:
Lamborghini Murcielago
Supercharged Viper 800 HP Special Edition #49 of 50
Porsche Boxster S
My Hummers:
08 H2, 22 in rims, 6 HID lights, 20 in TV with DVD
4 H2 limos 3 have lighted dance floors + ceilings, 1 has Zebra interior 24-26 passengers
H2 Limo 26 pass lighted dance floor (sold)
H2 Limo 24 pass (sold)
03 H2 (sold)
H1 Open top (sold)
FirstClassLimos.net - H2 limos and party buses in OH & PA
my car collection
07-12-2007, 12:37 AM
Have you seen the mod that I did a while back for relocating your license plate back there. I cut off that entire hub. It's not needed. You can get a new license plate light at Checker or Auto Zone too. Just splice it into the existing wire and mount the new light under the tire carier. Mount the plate to the rear bumper. And your done.
07-12-2007, 02:08 AM
I really like that mod. Glad ya did it!
07-12-2007, 07:25 PM
Kumho mkaes this one, and I think a 38" as well. Also, I believe that toyo has an M/T for a 24" wheel.
It's a 37" M/T on a 24" Wheel. gives it a profile of about 6.5" with a tread depth of about 1/2"
07-12-2007, 07:33 PM
yeah it's quick and dirty for now, I did this while I took a break from installing the Efans. I want to make something like what you have there - looks nice.
07-12-2007, 08:20 PM
What kind of wheels are those Tim?
07-13-2007, 12:47 AM
Holy Fat Tire Blingman!!!
07-13-2007, 02:31 AM
Have any more detailed pics of the plate light? Thanks for the pic....Jamie
07-13-2007, 05:53 AM
Originally Posted by NOMOYELLO
Thank u you for doing that.Anyone with rims and tires that does not have one on the spare is a LOSER.....
.....or just plain cheap
