07-23-2007, 08:28 PM
Back pass side window lock not working
For some reason I just noticed the PS back window goes down when locked ?.
We were on a road trip with the dog in the back and He hit the window switch with his paw so we locked them.
Then he hits the rear PS window and it goes down ?,The other 2 are disabled.
I just called my stereo/auto start installer and asked if he could have possibly did something,He said It definatly couldnt be from install.
I will bring it to the dealer when I get a chance ,Maybe in august when inspections due.
Anyone have a simular problem ?
Could the installer F'ed it up ?
The dog is smart and he likes putting down the window,I caught him red handed
07-25-2007, 08:52 PM
Re: Back pass side window lock not working
 Not one person when out to check to see if theres is working ?
07-25-2007, 09:48 PM
mine is working.
the answer from your installer that it definately couldnt be from teh install is BS. im not saing it is, but "definately" sounds BS. there are plenty of things he could have done while under the dash.
the lock button is connected to what looks to be a dark blue wire which goes to every single door. i think they travel under the dash in some harness to the other side.
looking at the wiring, if the wire is cut, then the window wouldnt operate at all, because that wire is supplying the power for the the switch.
hmmm... interesting. can you 100% confirm that all the otehr windows work (from their own door switch) and that this one does as well. and confirm that they all lock except this one.
07-25-2007, 10:08 PM
 confirmed and certified
I had the truck 2 years I never used them ?
I had GPS ect installed 4 months after purchase.
Are there 3 seperate wires comming off the lock switch ?
Maybe I have a bad switch?
Thanks for input, i'll look under dash and maybe right side panel for that wire this weekend.
07-26-2007, 11:31 PM
alright now that its confirmed and certified its still weird. go here http://hummeranswers.com/ and click on either front or back window wiring link towards bottom of page so you can see what im looking at.
it looks like when you press the lock switch that cuts the + that goes to center pole on the switches in each door. the motor is not directly operated by switch. switch goes to relay and then relay to motor.
So by the looks of it if it, the window will work when the dark blue wire has + going to the switch, but somehow its not stoping when the lock button is pressed.
Here is the weird part, all 3 windows are on the same lock switch, and 2 work but 1 doesnt. Something along the way is wrong but i cant put my finger on it. Nothing is cut or loose, since it has power, but something else is wrong.
I dont know exactly how the lock switch works, but if the 3 wires go in and make contact separately, maybe that one going to the window in question is sticking and not disconecting. have you ever spilled something sticky like juice or soda over the drivers switches in the past? that may be it if the switch works as i hope.
hope what i said makes the slightest sense.
07-26-2007, 11:56 PM
Good info not sure if i can check anything?
Word has a problem converting file ?
Maybe Ill let the dealer F with it next month.
thanks for link , Ill have to figure out why I cant open those files ?
07-27-2007, 12:00 AM
yea thres not really much that you can do, unless your good at reading schematics and find something that im missing on there. dealer would be your best bet.
those are word files so they should open alrite with word. are you opening with anotehr program?
07-27-2007, 12:15 AM
Box comes up
Microsoft word 97 conversion
 Unable to laod graghics conversion filter.Continue with document conversion.
Yes No
I hit yes and only text line comes up ? cant click on it either ?
08-01-2007, 11:54 AM
Dogs getting smart,goes to drivers side back window,then goes to the pass side and puts the window down every time !.
I guess its going to the dealer in the next week or two.
Odd problem I hope its just the switch ?
08-09-2007, 07:43 PM
I just came back from the dealer.
The pass rear window switch was not pluged in properly at the factory.
The pluged it in properly and all is good.(dog wont be escaping  )
I had to bring it in for inspection anyway .
I also noticed a few days ago that my pass side seatbelt warning light/tone was not working.?
They found I had a open short in the latch of the belt ,they orderd it and will replace it next week.
Odd
08-09-2007, 11:17 PM
that sounds odd to me, but glad its working now.
08-10-2007, 02:13 PM
08-10-2007, 05:41 PM
Originally Posted by whododat
 I clip/file the nails every 2 weeks,those suckers are still sharp ? I might try a rotary tool to round them off smooth.
And his paw was hitting the switch,he now seems confused  when going to the rear right window and it doesnt open.
08-17-2007, 08:34 AM
my 07 gray h3 passenger window is doing the same thing. I will need to bring it into the dealer and have it fixed.
08-17-2007, 02:38 PM
I wish I could disable the pass window and only have the back lock.
You might want to leave it the way it is.
When I sit in the pass seat its a pain when I want the window down.
