08-02-2007, 02:59 PM
Saving the Trails- what YOU can do
Off-Roading Tips
- Straddle ruts, even if they are wider than your vehicle. This will keep your vehicle level.
- Respect the rights of others while they recreate in the woods, even the Southern Utah Wilderness Alliance (SUWA) and Sierra Club members.
- Educate yourself and others about regulations and compliance to barriers, oh, and use maps and proper Leave No Trace ethics.
- Avoid wet meadows, stream banks, chasing wildlife and livestock and tromping on Cryptobiotic soil at all costs.
- Drive responsibly to protect your right to operate my motorized vehicle on roads in WILD lands and to help conserve those lands anyway you can.
- Use "tree safe" equipment for recovery should you need it.
- Leave nothing and take nothing while on the trail.
- Stay within the marked trail, going around an obstacle is cheating yourself, your fun, the challange and the environment.
08-02-2007, 06:34 PM
Re: Saving the Trails- what YOU can do
08-02-2007, 06:40 PM
Good points CP.  Too bad you can't put this in an appropriate place like the LU.  By the way is the first letter of each tip supposed to spell a word? It would be really cool if it did.
GO PENS
08-02-2007, 06:59 PM
I don't know why this thread is here. Most H1 owners are deaf and dumb.
Not all. But most.
08-02-2007, 07:24 PM
Not all. But most.
Easy now....
We need to keep our focus on the issue at hand, and deal with that issue later.
08-02-2007, 08:04 PM
A similar list:
- Cross streams slowly, at a 90-degree angle and only at designated trail fording points. This will help minimize stream bed damage and will help keep water out of the engine's air intake.
- Make the most of the environment.
- Yield the right of way for drivers on the uphill grade or overtaking you.
- Avoid slide slipping, which can start a rut, ultimately leading to erosion.
- Stay within the marked trail, going around an obstacle is cheating yourself, your fun, the challenge and the environment.
- Opt for"tree safe" equipment for recovery should you need it.
- Avoid mud if you can while remaining on the road or trail. If you can't, use low gearing and just enough throttle to maintain forward movement.
08-02-2007, 08:06 PM
Oh, thats much better, Thanks!
GO PENS
08-02-2007, 10:46 PM
LMAO!
