08-03-2007, 08:40 PM
How is camber adjusted?
Does anyone know how the camber is adjusted on the H3.
Is it the lower or upper control arms? where are the bolts located?
Victory Red 2006 H3 Luxury, Automatic, OEM steps, Sunroof. MODS: Torsion bars 4X, Front Bilstein shocks, Front adjustable swaybar links, Rear Rancho shocks, rear 6.5 inch shackles, Rear Quick disconnects swaybar links, Black rims, Hidden hitch, Husky mud flaps, Trasko spin on filter, No intake resonator, Enlarged 3" snorkel opening, No muffler
08-04-2007, 01:23 AM
Re: How is camber adjusted?
Thanks Humtech
At least I now know that the adjustment is made at the upper control arm bolts. It appears that there are a zillion ways to adjust camber in the automotive world (shims, ball joints etc..). About the the J 45938 tool?. I suppose it's to hold the control arm firmly in pace after you loosen the upper control arms bolt and to enable you to pull or push the arm with some degree of control.
Will see if I can do without.
08-05-2007, 03:13 AM
Ya not sure as I dont do any front end work, mostly electrical and drivability
