Old 08-29-2007, 02:39 PM
Steve #1 Steve #1 is offline
Steve #1 is on a distinguished road
Default Roof Rack / Basket Mounts
I'm designing a roof rack and looking for the best method for mounting. I'll most likely buy manufactured brackets. I'm looking for something that uses the existing track, or bolts in the track using the tacks mounting bolts. I have no interest in using the OEM cross bars, and the lower profile, the better.
If anyone has any suggestions and / or detailed photos of there mounts, it would be very helpful.
>>> Just to clarify, this is form my own use, I'm not trying to reverse engineer somebody else's mounts. I just can see paying $500 - $2000 for $100 worth of materials.
Old 08-29-2007, 04:29 PM
Desert Dan's Avatar
Default Re: Roof Rack / Basket Mounts
Contact Off Road Unlimited in Burbank CA.
My Defender Rack uses the existing track in the roof. I am sure you can order those mounting brackets separately. There are 3 brackets per side of the rack and it is very solid.
Here is the part # for the clamp kit DS24-6
ORU
http://www.offroadunlimited.com/Prod...t/PC/racks.asp
Rack details
http://www.offroadunlimited.com/Prod...idproduct=1080
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 08-29-2007, 05:03 PM
Spuds's Avatar
Spuds Spuds is offline
Location: Houston (The Heights)Texas <'))))>?{ . N 29.47.89 W 95.25.71
Spuds is on a distinguished road
I carry big sea kayaks on top of my H3. The OEM bars were not wide enough to fit two yaks side by side and clamping a wider bar on top of the OEM bar, put everything too high. I went with a Yakima system as I prefer the round bars that they use, over the square ones from Thule.
I got a Landing Pad #2, a Control Tower, and 66" wide bars. You may want to go with the 58" bars for a basket, but you can buy longer and cut them off to any desired length. I had to go back and get the 44" fairing as I was geting quite a bit of wind noise. The 44" fairing fits almost perfectly in the slight indent on the roof.
I'll try and get a picture of the components later.
Gone but not forgotten:
'78 CJ-7 4-sp w/granny
'81 Subaru 4x4 GL Wagon
'87 Jeep Grand Wagoneer
'91 Jeep Grand Wagoneer
'04 VW Touareg VR-6
'07 Hummer H3 I-5 Lux/Offroad
Current:
'03 Ford Ranger Super Cab FX4
'09 Hummer H3 Alpha Offroad
Handle every situation like the dog !!
If you can't Eat it or Screw it; Piss on it and Walk Away.
Old 08-29-2007, 05:52 PM
tower's Avatar
tower tower is offline
FWIW, the Landing Pad 4 & 5 work perfectly for an H2. The rectangular nuts fit into the factory roof rack. You just need to get them up to the bolt to catch the thread.
Old 08-29-2007, 09:58 PM
Thanks for the info guys, gives me a few options...... they're even proud of there mounts.
Dan, how do those mount to the rail? Are they two piece?
Old 08-29-2007, 10:26 PM
Desert Dan's Avatar
no pics sorry
two piece
each clamp uses two machine screws and washers to connect with a threaded pice of (upside down T shaped) metal that slides in the track. Then you bolt on an L shaped piece that provided a horizontal surface to attach the roof rack.
There are three on each side of the rack
Desert Dan
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 09-01-2007, 03:26 AM
JH3's Avatar
JH3 JH3 is offline
JH3 is on a distinguished road
I just picked up th eSurco Urban Rack. I you order the 45in wide model, you can use your existing crossbars and the rack (and rack floor slats) will mount directly to the crossbars. The rack uses track sider bolts and you can slide them right into the crossbars. its a nice clean install. If interested, i can snap some close up photos or jst go to surco's web site.
Old 09-05-2007, 08:59 PM
charlie06h3 charlie06h3 is offline
charlie06h3 is on a distinguished road
I used the Surco mounting hardware and crossbars for my rack. I brought the H3 OEM rack basket off eBay but the mounting hardware was lost in transit. Since the eBay seller couldn?t get the OEM mounting hardware and I didn?t want a refund. I began researching other mounting hardware. After looking into Thule and Yakima, I used the Surco CH100 with the 53 inch Safari crossbars. I think its a little taller then stock. The CH100 mounting hardware fits into the H3 roof tracks and the 53 inch crossbars fit nicely to the roof basket.
Old 09-05-2007, 09:19 PM
Thanks Charlie I was thinking about making something along the lines of the CH100 and after seeing a detailed pic, I don't think it will take much work.
Thanks guy for all the suggestions.
Old 11-10-2007, 12:43 AM
hummerconvert hummerconvert is offline
hummerconvert is on a distinguished road
Just installed my arb roof rack last night. Used factory track and arb fit kit for a Jeep Cherokee gutter. There should be a actual h3 fit kit out in the future, but this works for now.
