Old 09-08-2007, 01:59 AM
tomp's Avatar
tomp tomp is offline
Default Top Radiator Hose - Plastic clip removal?
Any idea how to remove the top radiator hoses' plastic clips? Thanks
Old 09-08-2007, 04:06 AM
tower's Avatar
tower tower is offline
Default Re: Top Radiator Hose - Plastic clip removal?
Photo, please.
Old 09-08-2007, 04:10 AM
tomp's Avatar
Surely you dont need a pic of this.....
It's the two large plastic clips that hold the top radiator hose tightly against the top of the upper fan shroud
Old 09-08-2007, 05:19 AM
tower's Avatar
As you wish, I guess it will keep until the next time I'm under the hood. I was just trying to expedite for you.
Old 09-08-2007, 03:39 PM
tomp's Avatar
Anyone?
Old 09-08-2007, 05:26 PM
Dug Dug is offline
Dug is off the scale
Tomp , it is hard to tell you. But you need a tiny screw driver to compress the little tab from the top end of the clamp . The area you compress is inside the bottom end of clamp . When you compress the tab it will unhook itself from the bottom half of tab. Hope this helps. doug
Old 09-08-2007, 05:28 PM
Dug Dug is offline
Let me try to make it more straight forward. Ultimately the top half of clamp pulls out of the bottom half of clamp when the tab thingy is compressed.
Old 09-08-2007, 05:30 PM
mikejr's Avatar
mikejr mikejr is offline
what Dug said.....or a sawzall....
2009 H2 Silver Ice LE
Old 09-08-2007, 06:33 PM
IRA51's Avatar
IRA51 IRA51 is offline
buy a new one ,50% of the time they can be reused . I just clip them off and change the hose and install a new one ,faster and less frustrateing .
A government big enough to
you have.
-- Thomas Jefferson
Old 09-08-2007, 11:50 PM
tower's Avatar
Sounds like a wire tie. Guess I'll need to look.
Old 09-09-2007, 03:48 AM
tomp's Avatar
Thx Dug, worked like a champ!
