10-19-2007, 03:20 PM
Removal of shift knob?
Anyone removed the shift knob on a manual trans? How you do it? Don't want to destroy it trying to find out!
10-19-2007, 04:16 PM
Re: Removal of shift knob?
10-19-2007, 04:39 PM
Already thought of that, might have to resort to it though.
10-20-2007, 07:36 AM
Before you go that far, pull the chrome cap off and see if there is a nut or a pin in the center of it. If it's a nut it is self explanitory. If it's a pin, you just have to pull it out..... while that sounds easy, when you get to the point that you've tried everything and given up, find a friend and pull harder. I don't recall all the details of what it took on my neighbors vet, but it was a lot more than I ever expected.
10-20-2007, 02:20 PM
10-20-2007, 02:28 PM
Better yet.
Go to dealer service. Tell the rep that you need the schematic of the shift knob assembly. They can print out a copy of the schematic, and it should have reverse engineering directions for un-install, and install, of the parts.
How do you think the dealer replaces parts when you bring it in for a service call? Not every mechanic knows the entire build of the vehicle.
10-20-2007, 05:05 PM
I had the shifter cap break off when it was 2 months old. I went into the dealer and they had to order an entire shifter to replace the (what they said was a $3 part).
I went in when they called only to find they had ordered an automatic shifter.
3 weeks later they got the new shifter in and installed it. The mechanic over torqued the thing during installation which resulted in a whining sound in 1st, 3rd, and 5th. I took it in and they denied the noise existed, claiming the K&N air kit was the cause.
Over a few months the noise is now limited to 5th gear and I put up with an annoying high pitched noise.
My advise is to not mess with it unless you know a high quality mechanic you really trust.
"I didn't mean to wreck him, I just wanted to rattle his cage." D.E. 1951-2001
10-22-2007, 02:36 PM
Originally Posted by Lex_Ordo
Better yet.
Good point I will drop them a line, they owe me for a day of service that never happened, drove two hours to have them try and find a rattle, had an appointment and when I returned to the dealer in the afternoon they hadn't put it up on the rack yet!  so much for scheduled apointments!
10-27-2007, 04:25 PM
The knob on the 5 speed is welded to the shaft. The shaft can be disconnected near the bottom. I was going to do as Tower suggested, then weld a nub on the top of the shaft that would accept the new knob. I just haven't found the time for it yet.
And my dealer is a hour from my home, I usually save up my problems then spend the whole day there. I wish they had one closer.
2007 H3 Lux/Adv 5 speed, Gibson Extreme Duals cat-back, K&N FIPK, PCMforless tune, SAW torsion bars, Samco Shackles, Fox Racing shocks, Trail Duty Bump Stops, 35" ProComp Xterrain tires w/Tactical Rims, Gobi Stealth Rack
10-29-2007, 02:51 PM
My dealer is two hours away so I am in the same boat. The sales guy was great but the service department still needs to prove themselves. I brought my truck in for a noise that was hard to pinpoint, specific RPM under load, bla, bla, bla. I had an appointment and they waited until just before I had to leave to put it on the rack even though my sales person told them I had a two hour drive to get home,  go figure... Maybe I can get them to do some things to make up for the dissapointment.
