11-11-2007, 10:59 PM
New Owner - Battery Question
So, I just picked up my H2 a few days ago and I couldn't be happier.
The previous owner had an aftermarket stereo system in the car. Before I took posession of the car the guy removed all his stereo stuff and put the factory system back in the car. He did however leave the battery he purchased. He mentioned that I need to get a smaller bolt to bolt down the terminal than the one that is currently in the battery. It can't tighten down enough and the terminal could possibly come loose. I'm bringing the car in this week to get a shorter bolt put in. My questions is do I want/need the battery he put in there or should I remove what he put in and bring it back to stock? Pics below & thanks in advance.
11-12-2007, 01:20 AM
Re: New Owner - Battery Question
what kind of hot wire cable is that that has the voltage reading on it? Never seen one of those, quite nice.
11-12-2007, 01:26 AM
I can check the cable and see if there is a brand or model on it. Its pretty neat... there's a little switch you flip to see the stats. Previous owner gets credit for it.
11-12-2007, 01:28 AM
I'd appreciate it, its nice. Oh and also most importantly, congrats on the rig!!! And also welcome.
11-12-2007, 03:42 AM
11-12-2007, 05:36 AM
Are you kidding? That's a dual Optima yellow top set-up. You aren't going to do any better than that! If you go off road, that's a nice power source for an electric winch. Keep it! Replace the bolt or shim it with washers but DO NOT trade those batteries for a factory one (unless, of course you do the trade with me LOL).
11-12-2007, 02:29 PM
 I would switch that battery setup right away ( I have a stock one I could send you free of charge in exchage for those not original ones).
Congrats on your new rig
Rene
11-12-2007, 03:42 PM
Thanks for the feedback everyone. So, the truck is only pulling from one battery and the second battery is for accessories (winch, lights, etc.) that I have on the truck? Just wanted to make sure I understand everything...
In regards to the washers... Do I need any special kind? I just keep putting them on until it tightens down? How tight should I screw it down? Also, is there any danger in messing with the terminal or is it a safe do-it-yourselfer?
Thanks again...
11-12-2007, 06:07 PM
Thanks for the feedback everyone. So, the truck is only pulling from one battery and the second battery is for accessories (winch, lights, etc.) that I have on the truck? Just wanted to make sure I understand everything...No, you do not have an isolator separating the batteries. So they both do the exact same thing. By having 2 you have doubled the capacity and available amperage compared to 1. But if you run the system down with the engine off (which is hard to do with 2 yellow tops) You will need a jump. You have no isolated back-up. A good auto-electric shop could put in an isolator for you if you really want one.
In regards to the washers... Do I need any special kind? I just keep putting them on until it tightens down? How tight should I screw it down? Also, is there any danger in messing with the terminal or is it a safe do-it-yourselfer?Just look at how much free space there is on the existing bolt. Then stack the washers a tiny bit thicker, so that it all can tighten firmly.
Thanks again...
Sure.
11-12-2007, 08:54 PM
Very nice setup!  I only have a single yellow top in mine.
11-12-2007, 09:02 PM
Originally Posted by ttkresurfacing
Thanks Tim....Jamie
11-12-2007, 09:03 PM
Where can you buy a yellow top, and how much more expensive are they than a regular set-up? Is it worth the money? Thanks....Jamie
11-13-2007, 07:51 AM
Jamie, you can get them in many places including Sears and sometimes Costco. About $175 seems to be the going street price these days. You know what they say, "Opinions are like ashholes, everybody's got one." I happen to think that yellow tops are great.
11-13-2007, 05:43 PM
11-13-2007, 05:52 PM
Interesting. Usually they will do a double barrel colostomy (one for the poop bag and the other is a mucus fistula) so that they can restore via reanastomose later. I've never heard of having ones ashhole sewn shut. Probably an ASSett in prison.
11-13-2007, 07:40 PM
that is a cool setup....keep the twin Yellow top...you'd be crazy to get rid of them....
Yellow top here as well...on three of my cars
11-15-2007, 09:04 AM
Those Battery Terminals are from STINGER Electronics product SHT301...they make some pretty cool stuff....
2003 Hummer H2
2000 BMW DINAN 5 (540i)
2002 HarleyDavidson V-Rod "FOR SALE"
All the great toys are on my driveway.....
11-15-2007, 09:08 AM
My brother is using one of these on his Optima battery ....which im i will be getting for my optima setup as well...
http://www.tsunamionline.com/product.php?id=477
Also Tsunami makes some great batteries....some of you might be interested...925amps..1200amps...1700amps...2150am ps.....sick!!!
http://www.tsunamionline.com/product.php?id=634
2003 Hummer H2
