01-23-2008, 05:56 AM
annoying rattle noise...
I'm hearing an annoying rattle noise coming from the rear of my H2 when I'm driving. It sounds like it's coming from under the cargo area. Does anyone know what the possible problem could be. I was thinking that the air compressor for the rear air suspension could be loose. Any ideas?
2003 Hummer H2 LUX...sold
2006 Hummer H2 SUT LUX...sold
2018 Polaris GEM e4
2022 Can-Am Maverick X3 XRS Turbo RR
2024 Rivian R1S Adventure
2024 GMC Sierra AT4X HD
2024 GMC Hummer EV 2X SUV
01-26-2008, 02:07 AM
Re: annoying rattle noise...
BUMP!!!
am i the only one having this type of problem?
2018 Polaris GEM e4
01-28-2008, 02:18 AM
I'm having the same noise, but it only comes in during acceleration. I thought it was related to some kind of heatshield. BTW, I don't have a compressor on mine.
06 H2 SUV....stock for now!
01-28-2008, 06:57 PM
I probably have the same rattle, but can't hear it above all the other rattles, creaks, and squeaks. LOL
01-28-2008, 08:03 PM
or two kids in teh back
01-28-2008, 11:43 PM
spare tire carrier???
rear control arm bushings???
01-29-2008, 03:55 AM
welcome to the hummer
01-29-2008, 05:40 AM
Check your exhaust mounts and or your air ride rubber mounting gromonts.
02-06-2008, 07:56 PM
i checked the exhaust and it seems find...i hope all there is to it is replacing the rubber mounting grommets on the air ride
2018 Polaris GEM e4
02-10-2008, 05:41 AM
Check the dust sheild behind the disc brake on the rear, I have a vibration coming from mine havent figured out the cure yet
02-15-2008, 08:56 PM
My hum makes the same rattle, on my BMW it was the calipers I going to check my calipers on the hum I know it needs new brakes on rear this might be part of the problem.
02-16-2008, 10:06 PM
i have the same thing on my 03' just started recently though. on acceleration it sounds like a loose heat shield. what i did find the other day way the header heat shields are rotting away from the header bolts. i doubt this is the rattle i was hearing though. my rattle comes from under the front, or at least thats what it sounds like from the drivers seat.
i've asked my buddy to lay on the ground while i run him over so he could listen, but he said i was crazy??? what are friends for? trust between friends isn't what it used to be, huh.
