02-17-2008, 05:46 PM
headlight adjustment
ok, is it a torx or an allen ?? what size and which way do i torq to to get the lights to point more toward the center of the road and down, im getting flashed THANKS
02-17-2008, 06:34 PM
Re: headlight adjustment
This has to be the first time someone on here has complained
about getting "FLASHED"
I have noticed the same problem since I converted to Xenon bulbs
maybe someone can help us out.
If I get to it first tonight I'll let you the size and direction to
adjust.
~Richard
02-21-2008, 06:17 AM
I tried to answer your PM but your mailbox is full.
~Richard
02-21-2008, 06:33 PM
Some have torx and some have phillips!
1994 Chev Suburban Blown
02-27-2008, 08:14 PM
adjust.
~Richard
What bulbs did you use? Any rewiring required to make the switch to Xenon?
02-28-2008, 04:05 AM
I'AM running an HID set i got on ebay and i believe porchette posted a link to the ebay store, they were like around a hundred i believe but they look much better than the regular bulbs you can buy, and they were "plug and play"
02-28-2008, 04:16 AM
No with Xenon bulbs they are just plug in 9007 bulbs. I have Euro Dezigns Xeon Krypton. And you pick a color / temp of the bulb, I went with the 8500K.
I think they are much better looking than stock.
And yes Matt I did not forget to let you know what size the torx was when ever I get to around to adjusting mine.
Does the HID ones you have include ballasts?
~Richard
02-28-2008, 05:44 AM
I've got Ultra White...and have been flashed once or twice....I just flash back and go on my way....hell, I used to get flashed in my truck worst.....
All I have to say to all those flasher's are..........Piss off and stop whinning.
02-28-2008, 04:35 PM
I never get flashed with mine. It is a lot of fun though to pull up behind a Miata or Corvette in an underpass and see them blinded when they come on automatically!
If you want the link, let me know or look up an old thread.
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
02-28-2008, 10:46 PM
Please post the link to the Xenon upgrades, I want em! I love flashin!
SJK
2008 H2 Greystone, Corsa Sport Exhaust
Luxury package, Air Ride, Nav, DVD, Sunroof
Sedona Leather (nice!!) Dark window tint
Euro/smoke tint side, top and rear marking lights
K&N cold air kit, GM lockpic
www.TeamShooters.com
02-28-2008, 11:09 PM
2008 GT2 Porsche
2009 DBS
02-29-2008, 03:43 PM
Thanks. Are these the ones you purchased?
The install looks a little tricky? I thought they were just bulb replacements. It looks like a entire wiring kit, relay to battery to ballast to bulb???
And its $500?? wow.
Stan
02-29-2008, 05:51 PM
I used this one, http://cgi.ebay.com/ebaymotors/H4-H1...23QQtcZpho to it?s the same kit. The wiring was real easy it would have only taken 10 minutes but I had to make ground straps because of the fiberglass hood. I ran the grounds back to the horns and took a few minutes to figure out they were not a good ground due to heavy paint where the horns mount. These lights are absolutely awsome!!! Although  I really dont like getting flashed.
2008 Solar Flare H2 - BulletProof 6" Suspension - Diamo DI17 20" x 10" - 38x15.50x20 Nitto Mud Grappler - HID 8000k -
02-29-2008, 05:55 PM
Ohhh the original question .... 2008 is 5/32 allen
02-29-2008, 08:34 PM
stupid question, will the "high" beams still work when flashed?
I heard xenon lamps cant do high beams because of the gas in the bulb?
Does that make sense?
02-29-2008, 08:58 PM
I just placed my order, hope they are GREAT!!
02-29-2008, 09:18 PM
I guess you figured it out but
Bi Xenon = Hi & Low Beam
Xenon = Low beam only
And even with the Bi's They are not brighter they just move the position of the bulb to shine higher.
03-01-2008, 06:54 AM
There are cheaper ones.
I got BI Xenon with 2 different wattage in the filiment
so you can flash to pass.
~Richard
