09-28-2008, 02:29 AM
sunroof deflector
has anyone taken this off and noticed a difference in the amount of air coming in...that you HAD to put it back on?
scott j.
2008 h2 sut
2008 escalade
1969 charger
09-28-2008, 09:27 AM
Re: sunroof deflector
Not yet, but I'm tempted to. At interstate speeds it begins to make an awful buzzing noise. I thought of resealing it, but not sure if it is the seal, or the integrity of the plastic itself.
09-28-2008, 12:52 PM
Took mine off for a while and it made a rumbling noise with the sunroof open, guess it is there for a reason
09-28-2008, 02:12 PM
X 2
09-28-2008, 03:54 PM
My sunroof rattles from this deflector and also the metal flap that goes across the back of the sunroof.
ANNOYING!!!
09-29-2008, 03:53 AM
ANNOYING!!!
I had the same problem with my '05.
2008 Black H2
09-29-2008, 04:00 AM
i took it off today...and the rumble is not very pleasant..if i put the back window down then its ok...i think i will be putting it back on even though i like the looks of it off.
scott j.
2008 h2 sut
2008 escalade
1969 charger
09-29-2008, 04:11 AM
Pic?
66' VETTE STINGRAY
07' Z06
09-29-2008, 04:23 AM
What did you do to fix it?
09-29-2008, 07:45 PM
Any suggestions on how to fix this problem? Is there a TSB for it, I couldn't seem to find one.
09-30-2008, 01:15 AM
Every car with a sunroof that we have ever had (maybe 9) is the same way. Without a deflector they all had that rumble unless you put a window down a little bit. Seems to be more an air pressure thing than anything. i don't really think its a design or equipment flaw.
10-01-2008, 11:24 PM
I agree...has to do with wind passing over the opening. I am sure an engineer could explain why it does it....easy fix...crack open a window.
2009 H2 Silver Ice LE
