10-29-2008, 07:08 PM
rear air springs
i have a 03 h2 and it has a slow leak in one of the rear air bags is there any way to fix it or do i have to just buy a new one and if i do is there any place i can get one that is pretty cheap
also how do i trick the senser to raise the rear up higher
10-29-2008, 08:50 PM
Re: rear air springs
I am willing to bet its a bad sensor. Not a bad bag. Bottom line is you have to take it to the stealer to find out. You cant work on it yourself without the tech2.
I had the same problem this year.
10-29-2008, 09:45 PM
im pretty sure its the bag cause i can hear it leaking and feel it coming out
10-30-2008, 11:11 PM
YOU PROBABLY NEED TO REPLACE THE BAGS, mine loose air if left undriven a week or so . as far as I know the only place to get new ones is the stealer . you do not have to use a tec 2 tool . you take the neg battery cable off raise the vehicle with the wheels hanging and replace the bags reconect the battery cable . and start and drive . I need a set myself for my 03,if I had the part # and could get a deal I would buy them myself. if anyone knows how to get them at wholesale let me know .
A government big enough to
you have.
-- Thomas Jefferson
10-31-2008, 02:06 AM
I agree, when replacing bags the tech 2 is not required, any sensors, module or compressor replacement would require a trim height learn to be done.
10-31-2008, 08:01 AM
I recently took the airbags off of my ride and don't even use them. When I studied them, they are actually in great condition, and look like they were replaced before I got my ride a couple years ago, so they are definitely newer than my ride. I will sell them to you if you can throw out a price... I will see what they are worth new and give you some sort of deal, since I do not use them anymore. Also, like someone said earlier in this post, you might want to double check that it's not a hose that's leaking and not the airbag. Those airbags are pretty tough, so if one had a leak, I would imagine it would split across and tear open, as with a hole in it, I don't think it would hold the pressure very well.
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
10-31-2008, 06:18 PM
on my 03 the bags look dry cracked at the bottoms (like dry tiney cracks you get on tires ) the best price I have found is $120.41 each for new OEM bags. I know as soon as I buy them an aftermarket company will make them and sell them for $80.00 each witch is all there worth anyway .
you have.
-- Thomas Jefferson
10-31-2008, 07:01 PM
ok I got a deal on new air springs,( $112.00 EACH) how do I depreasurise the system so I can safely remove the air springs ? the last set I did on a friends I unhooked the battery and jacked up the vehicle and punctured the air bag with a knife . is there another better way to do this without destroying the old airbag ?I was hopeing to do it this afternoon .
you have.
-- Thomas Jefferson
10-31-2008, 10:50 PM
Job done 24 min start to finish GM# 15938306 easy as hell ,had to stab the old ones with a knife to get them out .
you have.
-- Thomas Jefferson
11-07-2008, 11:41 PM
Yea, we're seeing some higher mileage 03's needing air bags lately. They leak at the bottom where they fold under. I just use soapy water in a spray bottle to find the leak. Just like in a tire.
11-07-2008, 11:58 PM
MINE ONLY HAS 75000 MILES .the Arizona dry heat is hell on rubber and plastic,but we don't get rust .
you have.
-- Thomas Jefferson
