Old 01-17-2009, 06:44 PM
RippSpeed RippSpeed is offline
RippSpeed is on a distinguished road
Default Gas tank discrepancy
anyone know for sure how big a 2005 Hummer H2 gas tank is ???
because I ran mine down to almost empty on the gauge and it said on my DIC that I used only 22 gallons and DIC said I only had 38miles of travel left ... Anyone know for sure ??? Specs say 32gallon tank but I dont know for sure...
Old 01-17-2009, 09:11 PM
working Hummer's Avatar
Default Re: Gas tank discrepancy
That's right 32 gallons. Mine is on empty at about 26 gallons which it leaves 6 gallons for reserve.
Old 01-17-2009, 09:15 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
x2.
-Brian
http://www.hummerguy.net
Old 01-17-2009, 10:04 PM
how far have you guys ran down your tanks ???
and what did the DIC read on mileage left ???
Old 01-18-2009, 12:47 AM
Hummer Guy's Avatar
"Low" comes on with about 3 - 4 gallons left.
Are you going on a long trip w/ very few gas stations around?
-Brian
Old 01-18-2009, 12:59 AM
yes, and its mostly steep mountain roads... on the way to our friends cabin.
But, I just was wondering because I thought it my gas gauge was way off ... So I wanted to assure myself that I'm not going to run out of gas...
Old 01-18-2009, 08:26 PM
Red face Re: Gas tank discrepancy
I was on a flat freeway going 65 when i had 11 miles to empty and run out of gas on the freeway
i coasted off the freeway and left the rig on the offramp shoulder,
good thing there was a gas station right on the corner.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
Old 01-20-2009, 10:28 PM
HumminNBoatin''s Avatar
x3.....Usually 26gallons gone when the light comes on. The most I ever had to put in it was 29 and some odd gallons. If you are doing long hauls or towing and have LARGER than stock tires pay no attention to your computers calculated gas usage. Its going to be off. Mine is always within a gallon but it gets way out when towing the boat on long hauls through the mountians.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 01-21-2009, 12:54 AM
yeah I corrected with my Diablo Programmer ... So my computer is calibrated to 35" tires. Its pretty damm close, when my fuel usage meter says 22gallons used ... It take 22 gallon to fill up. Just the travel mileage left on the gas tank is off big time...
At 22gallons it says I have 38miles left on the tank ... And if the tank is a 32gallon tank that still leaves me with 10 gallons. Either way, with the programmer and adjusting how I modulate the gas pedal; I've been gettign 13.2mpg instead 11.3 mpg before...
