02-09-2009, 03:46 PM
How to turn engine oil change indicator of
Hi again.
Another question.
I don`t want to pay a lot of money, getting my H2 serviced. I want to make service myself.
How do I re-set the indicator ??
Paw
02-09-2009, 06:18 PM
Re: How to turn engine oil change indicator of
Bring up the engine life on the display then push and hold the reset button (it is the bottom button and the passengers side of the steering wheel that has the arrow pionting toward the drivers side door.) At least that is the way I reset mine. I have a 03.
"A clear conscience is usually the sign of a bad memory."
03 White H2
12 HID lights, factory lightbar, custom light bar for brush guard, OEM luggage rack, k&n intake, Gran MAF, 37" Toyo M/T's, 17x12 weld racing wheels, predator programer, Dynomax 4" catback exhaust,
02 10th Anniversary H1 #44 Will be missed
94 Custom pearl white H1(work in progress)
Too many mods to list
06 kawasaki stx-15f
02 yamaha superjet
02 polaris scrambler 500
02-09-2009, 10:50 PM
I have never heard of using a button to reset the engine oil life indicator? I just turn my key to "on" with the engine off, and press the gas pedal 3 times then shut off the key. done.
02-09-2009, 10:54 PM
This is how I do mine also....
02-10-2009, 06:40 PM
Its in the owners manual, but I think it has something to do with tapping the gas pedal with the truck key turn on but the engine off. It then chimes. I will check to see though
06-25-2009, 02:19 AM
Bring up the long block engine life on the display then push and hold the reset button (it is the bottom button and the passengers side of the steering wheel that has the arrow pointing toward the drivers side door.) At least that is the way I reset mine. I have a 03.
My friend does the same way too. But he made it after trying several times. Anyways, can you recommend us where to get some manual for this? Can't find mine at the basement.
06-25-2009, 02:41 AM
http://www.gm.com/gmownercenter/hummer/ Got to sign up though
06-25-2009, 02:59 AM
Originally Posted by Easy Ed
gm.com/gmownercenter/hummer Got to sign up though
Thanks, gotta sign up later need to install some flash first.
06-25-2009, 11:17 AM
You are welcome.
What year owners manual you looking for ? I have a Adobe Acrobat copy of the 2003 and the 2005 model years that I would gladly e-mail to you, their only approx 3 mb in size. Don't ask why, but I keep a copy of the 2003 manual on the BlackBerry so I don't have to open the glove box to get the hard copy out
Ed
