Old 02-14-2009, 01:17 PM
DoubleAction's Avatar
DoubleAction DoubleAction is offline
DoubleAction is on a distinguished road
Default How to remove inner tailgate panel
Please help me with removing the tailgate inner panel specially the upper one were the stop light is.
i've done a search but there was nothing about my question
thanks in advanced
- HUMMER H3 Lux/Pkg (Boulder Gray) 2006
- Audi Q7 (White) 2009
Old 02-14-2009, 10:00 PM
fourfourto's Avatar
Default Re: How to remove inner tailgate panel
Not sure if its in here,its a good link to save anyway.
good luck
Link http://www.hummeranswers.com/
Old 02-15-2009, 05:35 AM
good luck
Thanks Bro but it seems that this information never been out on the net, any way i tyred to do it my self , this is how :
1st remove the lower panel usually black by pulling it from the corners.
2nd you will find the upper panel is attached to the door frame with 4 black retainers which you can easily pull out but the problem is with the 4 metal clips that are holding the panel from the top they are difficult to remove i tyred to remove one and broke it
Old 02-15-2009, 02:48 PM
fourfourto's Avatar
I find these pry bars work well under panel clips,I picked up a set last year and used them a couple times and I havent broke a clip yet.
LINK http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=95214&CategoryName=&SubCateg oryName=
Old 02-16-2009, 05:36 AM
I allways use those to pry panels but the clips were held firmly and i used a little of force
