Old 02-24-2009, 03:28 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
Default Updating Radiator (Extra Insurance)
Has anybody changed there Rads for aftermarket, and if so what brand, how much, and where??
Thanks in advance. Ed
2004 Hummer H2 " Metallic Red "
20 inch Mojave's (Teflon)(325/60/20) BFG A/T's
MagnaFlow kitty back...Hypertech Tuned..Music to my ears
HCMI Member 50043
Old 02-24-2009, 04:08 AM
Default Re: Updating Radiator (Extra Insurance)
I did but it basically happened when I installed the supercharger anyways.
I talked to a tech friend of mine and he made a good point that for the most part, if the lines break going into the trans, it doesn't get into the antifreeze.
I was going to do mine for safetly but think I'll pass right now.
Food for thought...
Mark
Old 02-24-2009, 04:20 AM
Thanks Mark I'll keep that in mind.
HCMI Member 50043
Old 02-24-2009, 07:02 AM
tomp's Avatar
tomp tomp is offline
I changed mine out for a Ron Davis dual core radiator without the internal tranny heat exchanger and then added a tru-cool tranny cooler with thermal bypass. Engine/tranny never get hot anymore, but still have a problem with power steering getting too hot when offroad in tight corridors and moving slow where no air makes it over PS cooler. This only happens offroad in summer heat
The Ron Davis radiators are not cheap but are worth every penny. If I had to do it over again, I would do the electric fan conversion as well
Old 02-24-2009, 06:56 PM
H2 Bill H2 Bill is offline
I got mine from Breathless Performance and it works great! I too have a SuperCharger.
http://www.breathlessperformance.com...20Radiator.asp
1994 Chev Suburban Blown
Old 02-24-2009, 11:01 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
You sure got that right! I just discovered that one of the wires running to one of my brushguard mounted off-road lights was resting against one of the coils on the power steering external cooler. The cooler got so damn hot that the flex conduit that protected the wires was melted and fused to the cooler. At least the flex conduit did it's job and protected the wires, or there would of been a dead short the next time I turned on the lights! I'm really thinking of a mod to keep the PS fluid cooler, like an aftermarket PS cooler (if there is such a thing).
I wouldn't mind a higher capacity PS pump either!
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
Old 03-01-2009, 03:38 AM
Thanks for all the replies, I do value your opinions.
HCMI Member 50043
Old 05-24-2009, 08:02 AM
CONRAD II's Avatar
Can I see a pic of the radiator setup with the supercharger install....
66' VETTE STINGRAY
07' Z06
