Old 03-13-2009, 10:39 PM
jmsspratlin's Avatar
Default Tranny Flush
Is the Dextron III the only recommended trans fluid to replace the stock fluid? I have reached 33K and need to flush the old fluid.. Thanks in advance....Jamie
Old 03-14-2009, 01:37 AM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: Tranny Flush
You could use syn ,mobil 1,or Redline,or Amsoil.
A government big enough to
you have.
-- Thomas Jefferson
Old 03-14-2009, 02:32 AM
Thought there was an issue that only Dex III was suitable?
Old 03-14-2009, 02:35 AM
HummerMann's Avatar
I think they recommend changing the fluid at 50K in the H2 owners manual, but it's cheap insurance to change it earlier and I've done some serious towing! I had my '06 done at 38k at an AAMCO dealer in one hour for 220. They told me the flush is a dealer tip off and doesn't do anything - to just change the fluid.
Hummer, like nothing else
Old 03-14-2009, 02:39 AM
Isnt there a difference in dropping the pan and flushing while changing the filter? arent you suppose to do all three things? i used royal purple in my truck and if you really want insurance you need to do the "tranny cooler bypass" search it
Old 03-14-2009, 03:07 AM
tomp's Avatar
tomp tomp is offline
GM discontinued the use of the Dex-III branding and recommends Dex-VI (6) as a replacement. The only full synthetic that meets this requirement is Redline and GM fluid. However, it was quite a while ago when I researched the companies and their Dex-VI specs so others may be on board now and have it too.
Old 03-14-2009, 06:03 PM
H2R's Avatar
H2R H2R is offline
H2R is on a distinguished road
It is my belief that Maintenance Schedule provided by GM is just that a recommendation under normal use. I have been wheeling in deep sand and have brought my Transmission temperature to above 200 degrees. My experience tells me the trans fluid breaks down above 170 degrees so I would change it. The only reason It went up is because I didnt air down like I should have. I have always used the dealer just because I want GM coverage.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
Old 03-14-2009, 07:31 PM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
Valvoline is marketing a full syenthetic DEXVI that has the GM approved license markings on the container as well.
Old 03-20-2009, 08:32 PM
Mr. I - Man's Avatar
So what yall are saying is that dropping the pan and changing the filter and fluid is not enough? You have to have it flushed also? If this is true is it better to have it flushed first then replace the filter and fluid again? Also I was thinking about upgrading the servo if I was changing the filter anyways is there a big difference in the OEM corvette servo and the billet one? I mean its going to be in my trans who cares if its made from shiny billet no one is going to see it? Plus I'm allergic to Billet Chrome.
Josh
Old 03-20-2009, 09:40 PM
Exclamation Re: Tranny Flush
Any Ideas??? I kinda need to get this done this weekend. I have a long road trip next week and I have about 58k on the beast and want to service the trans,
Old 03-21-2009, 04:29 AM
You guys are no fukking help so I guess off it to the stealership I go
Old 03-21-2009, 04:59 AM
Stealers trans service does everything u need , just overpriced
Old 03-22-2009, 01:50 AM
Do they replace the filter also????
Old 03-22-2009, 02:31 PM
KANE's Avatar
KANE KANE is offline
KANE is on a distinguished road
I believe they do not change the filter...I think the flush will purge the filter in place.
Hope it helps!
Old 03-22-2009, 07:39 PM
Badace's Avatar
Badace Badace is offline
Badace is on a distinguished road
Sounds like a Sanfrancisco Vice team mission. "Operation Tranny Flush"
Lol
January 20, 2009, A Dark Day in American History. Tehee.
Sold. Miss u buddy.2006 SUV LE Demonguard and extras.
Looking
