08-14-2009, 05:37 PM
H3/H3T Stereo Install
I am looking at installing a navagation/dvd "slide out" receiver, i found the mounting bracket and onstar plug-in for it on Crutchfield.com, but how in the heck does the old radio come out? I've been looking all day to find screws and clips but havent been able to locate all of them. Has anyone changed out their radio yet? Any suggestions? The dealer is not help here in Buffalo, they barely know enough to work on the hummers and they wont give out any schematics or hints. Thanks!
2009 H3T, 5 Speed, Power Seat, Tow Package, Chrome Package(not by choice!), 2" Suspension Lift, 1" Body Lift, Custom Front Hitch Receiver Setup, Used USAF Aviation Fuel Receptical Mod(pix coming soon!), Off-road OEM Roof Lightbar, Custom made Back Rack, Jenson DVD/NAV/IPOD System, etc.
08-14-2009, 09:22 PM
Re: H3/H3T Stereo Install
I saw a similar post on another forum....I believe they said that the dash is only held on with clips. They said to place a small flat head screwdriver under the silver part of the dash and pry it away...it will unclip.
I hope that helps!
2007 Hummer H2
2010 Jeep Rubicon
08-14-2009, 09:56 PM
Put your fingers into the 12v outlets and pull up and out. It should "pop" off its clips. You'll have to disconnect the plugs for the a/c and such. Good Luck!
Luke
MaineH3
'06 - Superior Blue Lux. H3
08-14-2009, 10:26 PM
It does pull off...
The first time its very stiff.
There is a good study on this done by "f5stop" do a search on Navigation or Stero intall he put a AVIC unit by pioneer in his about 3 years ago.
Good Luck!
08-14-2009, 11:17 PM
Originally Posted by wpage
It does pull off...
Good Luck!
Ditto. I printed out f5fstop's post and used it as a guide when I installed my unit in the '06, uninstalled and put in '07, and again in the '09. A bit time consuming to get it right, but nothing tough.
08-18-2009, 07:10 PM
I pull the silver dash part away from the top in the center.. Then you can get to the 4 screws holding the radio in.. Make sure not to insert the key to turn the truck on. You will get a service 4wd if you have the harness unplugged from the diff control panel..
08-18-2009, 09:32 PM
Thanks for all the help, I'm going to try doing the install this weekend, i had to order the OnStar adapter from Crutchfield's. I'm debating on ordering this subwoofer box (pictured below) and buying similar stock black cloth interior to wrap it so it matches the truck, let me know what you think. I mostly listen to classic rock, rock and a little country but i like a little clean bass.
08-19-2009, 02:03 AM
I've pulled mine apart several times, in all three H3's. It is much easier to do with shifter all the way in L, which requires the key to be on. The service 4WD does come up, but when all is buttoned back up it goes away quickly.
08-21-2009, 05:32 PM
Got the head unit installed with the GMOS-01 adapter, works great, SUPER EASY TO INSTALL!! My buddy that was helping me did put a scratch in the panel, so now i need to find someway to cover it or fix it... friends... lol. Still debating on the sub-box above. But i think the H3 is larger in the back than the T, so idk if the box would even work... might be too big seeing as its built for a regular H3.
