10-02-2009, 03:02 AM
Re: 2008 hummer h2 Bluestar Install
hi this is the kit for 2008 h2
BlueSTAR PnP GMLAN-29 Complete Kit .................................................. ..........$279
Includes BlueSTAR PnP-GMLAN and Motorola HF850 junction box
10-02-2009, 03:59 AM
Since it looks like a lot of us are buying this, perhaps they would offer the forum a group buy????
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
10-02-2009, 04:08 AM
hi email Chris techsupport@costartech.com and ask him maybe?
10-02-2009, 04:35 AM
awesome write up. i did talk to tracy on the bluestar today and literally, it sounded like he was on his home phone. superior quality and very clear with no echo. i sent a email to chris to see if he can do a group forum buy. i will keep you posted as soon as he emails me back.
scott j.
2008 h2 sut
2008 escalade
1969 charger
10-02-2009, 03:38 PM
Got an email from Chris. We can get a group buy with a discount of $29.00 each for a commitment of 10 people. It's up to all of you !
2008 GT2 Porsche
2009 DBS
10-18-2009, 05:44 PM
***** When you open the bluestar box you will first need to plug the circuit board into the black motorola box and wire tie the cardboard to the bottom of the circuit board. This will protect the circuit board and keep it for shorting out on anything.
Originally Posted by twr
Install a Bluestar unit in your 2008 h2 with or without a lockpic GMX 322.
I should add non navigation radio's install is basically the same.
When a call comes in or you calling out. It will mute the radio and turn down heater fan speed, then all will resume after the call has ended.
This is the kit # for a 2008 h2
**BlueSTAR PnP GMLAN-29 Complete Kit ..........$279 **
Someone will ask about older hummer models. The install for these models will be different than the pictures below.
Kit # for H2, 2003/ 2007 or H3, 2006/2007
**BlueSTAR PnP Class2 Complete Kit ......... $249**
STEP 1
10-22-2009, 04:46 AM
I would be intersted in a group buy. Doesn't looks like it picked up much steam though? I would be buying one for a 2003.
10-22-2009, 02:38 PM
Look down the page, you'll see the info on the group buy!
http://www.elcovaforums.com/forums/s...ad.php?t=38274
2008 GT2 Porsche
2009 DBS
10-22-2009, 03:09 PM
looks like the sale ended on 10/19...just missed it!
10-23-2009, 01:49 PM
hey, do any of you guys know if the gmx 322 will work on my 2006 H2. i have the factory navigation, but it wont let you put a movie in and play it at all, not even in park. just says "dvd error check map dvd" when you try to install one. since it looks like it wasnt made to play a movie will the kit convert it to do so??? this may have been asked here before but i couldnt find any info on it. thanks for any help you guys can give.
10-23-2009, 03:33 PM
Hi your nav radio does not play dvd's on screen and the GMX322 will not change it so you can watch on screen. Its unlocks 2008/09 hummer and 2007/09 gmc trucks nav units that play dvd's on screen, to play when out of park or while driving and to plug in a addresses while driving. Its also lets you turn camera's on any time if if have them. Hope this helps.
10-25-2009, 08:22 PM
got mine installed and i must say...its a really nice unit and it sounds (on both ends) as good as a land line. i wish i would of bought this sooner...thanks tracey for the info on both the unit and the install.
scott j.
2008 h2 sut
2008 escalade
1969 charger
10-26-2009, 01:12 AM
Hi Scott your welcome, glad you like it, i knew you would and no problem with the install pictures. Tracy
10-26-2009, 03:37 PM
thanks for the reply, i actually found a kit that will allow me to play dvd's on my 06 screen, but i think i have to use an external dvd player...i think i can use the one in the console to play on all three screens. so far the only way to unlock the nav while in motion feature is to do the toggle switch on the vss wire like i read in another post.
10-26-2009, 10:15 PM
hi cyclone53, if you use the switch to turn the vss off the gps will not be tracking at that time i don't think. What is the kit you found to play the dvd on screen for your 06?
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
10-27-2009, 02:15 PM
its the universal kit listed on this website. the video show my exact model radio...
http://www.coastaletech.com/gmlockpick4.htm
but i think i still have to use a external source for the dvd player, unless i can get the console dvd to work. i read about people using the switch method and they say they just flip the switch to input the address and then switch it back to resume normal operation.
10-27-2009, 10:27 PM
Hi cyclone53, i think your right you need a external DVD player for your 2006 truck. With my GMX322 its not gps tracking if i am watching a dvd on the front screen with the lock pick turned ON. If i am just watching the rear screen with the lock pick truned OFF as it comes from hummer then the gps is tracking. Below is from lock pick. I am not 100% sure in your truck but its likely the same. So you would have to turn OFF the front dvd screen to go back to gps tracking. Hope this helps
**During the time that you are actively viewing a factory DVD or factory AUX video while in
motion, OR while you are inputting an address or taking advantage of the other radio unblocking
technology, active map tracking is not occurring (if you switch to the map view immediately from
an unblocked function, the map will not be moving or pinpointing your exact location). Press the
MUTE button two (2) times as mentioned above to immediately restore factory operation and
begin map tracking again. It may take several seconds for the map to recalculate your current
position.
**Use of the factory camera, aftermarket cameras or either of the 2 Video/Audio inputs available
on the GMX-322 while in motion does not affect active map tracking while on.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
