05-23-2005, 03:17 AM
anyone know this good info?
(with insurance)
05-23-2005, 03:30 AM
Also love to know what wheels will fit. I talked to a guy at Superbuytires, and he said the brakes were big, and the only thing he had to fit is the Asanti Wheels that are made to clear big brake kits... I think this is BS though. Wonder what the biggest wheel size will be?
05-23-2005, 01:19 PM
Bolt pattern is the same as the Colorado. I am not sure on the offset. Weld is supposed to have some available for it already.
05-23-2005, 02:29 PM
whats the bolt pattern on a colorado?
(with insurance)
05-23-2005, 05:02 PM
6 lug 5.5" bolt pattern
05-23-2005, 05:54 PM
Thank H3 Builder!
I was going to ask you as well!
05-29-2005, 01:58 PM
I had a guy from a wheel place say the bolt pattern is 8x6.5
Is he wrong H3 Builder?
05-29-2005, 02:13 PM
Wrong. 6 lug 5.5" bolt pattern. The same equipment for tightening the Colorado lugs fits the H3. So Colorado-H3, same bolt pattern.
05-29-2005, 05:18 PM
Hardly anyone knows about the H3 yet in the aftermarket wheel companies. They all assume that it is a H2...
H3 Builder is the man, thank you very much!
06-02-2005, 02:04 AM
if it's hub-centric, I think that is also the Tahoe's pattern. which would mean there are hundreds to choose from
06-02-2005, 02:27 AM
I think there is a backspacing issue vs. the Tahoe.
06-02-2005, 02:52 AM
Maybe this will help.
http://elcova.com/groupee/forums/a/tpc/f/2706067735/m/934109...831025521#2831025521
I don't know if the '05 Col is different than the '06. Since they should be the same as the H3 all should be good. Maybe.
We need to know the backspacing, which no one has provided, to be sure.
06-02-2005, 04:58 PM
I called Discount Tires, they said they also have no info on what will fit. They will usually send a rep to the dealer, and measure the backspacing, offset, and center bore to see what will fit... They said they won't do that till they get like 10-20 calls a day for rims for the vehicle! So, if you are interested in wheels start calling these guys!!!! LOL
http://www.tires.com
06-02-2005, 10:36 PM
I had Greg Weld from Weld wheels out here today and he has 17", 18", 19", and 20" wheels that will fit the H3 now. I will most likley have a set on by next week and will post some pictures.
06-02-2005, 10:49 PM
I talked to a guy from Wheel Pros he has you need -18 or 19 offset, and large bore.
06-02-2005, 11:59 PM
Hey KC,
That would be great if you can get some pics. Is Weld is still headquartered there? By the way, didn't just do the dealer training? Its been a long week so couldn't remember when it was you were supposed to do it. If so, what were your thoughts?
