Old 11-09-2009, 01:39 AM
h24bob h24bob is offline
h24bob is on a distinguished road
Default heater motor noise
have a 2003 when fan is turned on for interior heat it makes a louder than normal sound especially on hi ,it sounds as though the motor is struggling ,heat and blow is good ,any suggestions ,how do you access motor is it behind the dash on right side ,is there a filter that could be blocked up
Old 11-09-2009, 02:10 AM
Intercooled's Avatar
Intercooled is off the scale
Default Re: heater motor noise
Not sure about location. But I believe the 03's had a cabin filter. Hopefully someone with an 03 will chime in here.
2006 H2 SUT Fusion Orange LE
Old 11-09-2009, 03:08 AM
Easy Ed Easy Ed is offline
Some 03's and some did not, mine does not.
Check through some recent post, someone found a mouse nest in theirs and gave directions to remove it. If I find it I will post a link here.
Here is the promised link http://www.elcovaforums.com/forums/s...ad.php?t=38414
Later, Ed
Old 11-10-2009, 12:53 AM
Thanks Ed great link ,i will take a look at it on the week end
Old 11-10-2009, 01:11 AM
Good luck, let us know how it goes, Ed
Old 11-15-2009, 03:36 PM
ok stripped out the heater motor this morning took about 40 minutes to get, it out and put back, instructions were great.when i pulled the motor out there were some pine needles and debrit in the fan cage cleaned everything out and it works great .i guess those needles were enough to put a load on the fan .Thanks again for help.
Old 11-16-2009, 02:53 AM
Congrats on the fix
Old 12-06-2009, 03:44 AM
Braveheart7's Avatar
Braveheart7 Braveheart7 is offline
Braveheart7 is off the scale
Awesome Glad I managed to help someone rather than everyone helping me....
