Old 03-18-2010, 03:56 PM
HummerJim's Avatar
Default SUT Rear Window
My rear window won't go up or down on my SUT. I'm thinking it's a fuse, but I can't locate any fuse that says rear window and everything else seems to be working fine. Anyone know where that fuse is?
Old 03-18-2010, 10:05 PM
H2BossHog's Avatar
H2BossHog H2BossHog is offline
H2BossHog is on a distinguished road
Default Re: SUT Rear Window
I had the same thing happen, dealship fixed it under warrenty, said is was a bad switch and something about the wiring, I'll see if I can find the reciept from that visit.
2009 - H2 SUT
Old 03-18-2010, 10:34 PM
Easy Ed Easy Ed is offline
Inside fuse panel.
From a 2005 owners manual on page 5-105.
Circuit Breaker, AUX PWR 2, Midgate Controller (SUT Only)
Maybe ???
Old 03-19-2010, 12:29 AM
HummerJim's Avatar
Thanks! I found it and the fuse is fine. Just to be safe though I replaced it with a new one. I'm going to have to schedule a visit to Lynch.
Old 03-19-2010, 12:31 AM
I'm sure I'm stating the obvious but did you fold the rear window panel at all?
I ask that because many times I've folded the rear panel down and when I put it up, I didn't "click" it in all the way in and it didn't allow the window to go up or down.
Like I said, probably obvious but sometimes....
Mark
Old 03-19-2010, 01:44 PM
HummerJim's Avatar
That was it. I hauled some 2 X 4s two weeks ago and thought I had put the back up tight. This morning I went out laid it down and put it back up and voila, the window works again! It looked like it was closed tight and there was no air noise, or maybe some switch just needed to be recontacted. It just needed a good shove to lock into place I guess. You saved me a trip - thanks - diesel man.
Old 03-19-2010, 01:55 PM
No problem Jim, I didn't want to sound like I was insulting you but sometimes in our haste, the simple obvious things escape us.
Glad it worked out.
Mark (aka diesel man...lol)
PS. Didn't you have a light on the dash showing anything? I would have thought that either a light on the dash would show or your dome light wouldn't shut off.
Old 03-19-2010, 03:01 PM
HummerJim's Avatar
Didn't notice any light. I have my interior lights either deactivated or removed. They draw mosquitoes and bugs from the Lake by the dozens at night when you open the doors.
