Old 06-24-2008, 05:51 PM
HSTONKA HSTONKA is offline
HSTONKA is off the scale
Default 4wheel drive switches...stays in Neutral?
Sometimes I get in my truck, fire it up and the red light stays on for Neutral, and never switches to 4 hi. I can press the 4 hi button and it will stay in 4 hi. But I have also noticed that if I forget to look and I'll be driving and it will still be in Neutral (redlight) and not driving any different at all than if it was in 4 hi. Its out of warranty, any suggestions?
Old 06-24-2008, 10:17 PM
HummerMann's Avatar
Default Re: 4wheel drive switches...stays in Neutral?
This happened on a few '05 and '06 models. There is a thread in here in the technical section in the summer of 2005. As I remember it's a relay that is cheap and easy to have replaced.
Hummer, like nothing else
Old 06-26-2008, 07:56 PM
pdsq99f4 pdsq99f4 is offline
How's your battery?
Old 06-30-2008, 09:48 PM
battery has never been replaced, '05 SUT with 55k on it......
Old 07-01-2008, 03:11 PM
You may want to have the battery checked out to make sure it is up to par. You could be having a low voltage situation to the tccm when first starting it up causing it to do weird things.
Old 05-09-2010, 06:57 AM
BUMMER BUMMER is offline
BUMMER is on a distinguished road
I would like to revive this thread. Ive been experiencing the same problem. My TC tends to go from 4HI to The RED NEUTRAL Light on it's own. I would like to resolve this myself before taking it to the dealer. From the info I have gathered these could be some of the fixes but would like to hear from others who have resolved this
1- Replace TCCM Actuator?
2- Replace relay fuse?
3- Replace Encoder motor?
4- Go through all TC drives 25 times?
Old 05-09-2010, 12:45 PM
HummerJim's Avatar
I can't find the old thread on this but I remember something about going from 4Hi into 4 Lo and 4 Hi lock several times to see if it clears things up.
Old 05-09-2010, 02:57 PM
Jim, I believe that would be similar to what Ive read by going through 4HI and 4LO 25 times. I don't see how that would work but I will give it a try. The funny thing is when the TC goes into Neutral, the truck seems to drive smoother however my gas mileage only averages 8.9 at best!!
Old 05-09-2010, 05:25 PM
Question Re: 4wheel drive switches...stays in Neutral?
i am having the same issue.
i thought maybe since i have not change my transfer case fluid (52K miles) it may be a warning to change it?
if you guys find a fix please post it.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
Old 05-09-2010, 05:39 PM
Cesarjajr, does your light stay in Neutral or does it go back and forth to 4HI like mine? Has your gas mileage changed?
Old 05-10-2010, 06:49 PM
it stays red in netural, i have to hit the 4 hi and then it will stay on 4 hi.
it happens on and off. i shift to drive and sometimes it's red in neutral.
some times im already driving when i see it in red neutral and didnt see when it changed.
i have seen no dip in miles + or -.
Fabtech Tie Rods
Old 05-11-2010, 12:13 AM
The_Yeti's Avatar
The_Yeti The_Yeti is offline
The_Yeti is on a distinguished road
This happened to me the other day and even the service 4wd came on after trying to switch. I pulled over turned off and then cycled thru the choices. seemed to work. I didn't do it 25 times but should probably give it a run thru. I've searched the issue on this site. Some say sticky cyleniod or error from never using. So I plan to cylce thru the 4wd choices and air ride height adjustment more often.
Old 04-27-2011, 03:36 AM
rmutchler's Avatar
rmutchler rmutchler is offline
rmutchler is on a distinguished road
Older post, but my SUT suddenly started having the same problem. Does driving while the neutral (red light) is on hurt anything? I Ned to have it looked at, unless someone knows the solution...
Old 04-27-2011, 07:21 AM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
I just posted a thread on this myself.
This just started on mine after I installed 2 new hubs. Never did it before, so I thought it was related - Maybe not?
Cognito UCA - Leveling Kit - Kryptonit Tie Rods - Bilstein Shocks - Cognito Support Kit - 37X12.5 Cooper Tires - Pro Comp 8128- Mercury Balancers
Old 06-28-2011, 03:51 AM
rmutchler's Avatar
Took mine to the dealer today...broken fork in the transfer case...$280.00, covered on my warranty.
