06-13-2010, 02:48 PM
need a recommendation
Hi There...
I'm planning to buye Rockstar XD rim 20"x10" and Toyo Open country MT 38"x13.50x20, jus I want to ask if there is any problem when I install them on my hummer? or I need to make some modifications before installing?
06-14-2010, 03:03 AM
Re: need a recommendation
Your probably gonna have to crank your torsion bars in the front unless you only plan on making straight turns. I have the toyo 37/13.50 and I have the green keys and I still rub sometimes if I hit a drive way entrance too fast.
"A clear conscience is usually the sign of a bad memory."
03 White H2
12 HID lights, factory lightbar, custom light bar for brush guard, OEM luggage rack, k&n intake, Gran MAF, 37" Toyo M/T's, 17x12 weld racing wheels, predator programer, Dynomax 4" catback exhaust,
02 10th Anniversary H1 #44 Will be missed
94 Custom pearl white H1(work in progress)
Too many mods to list
06 kawasaki stx-15f
02 yamaha superjet
02 polaris scrambler 500
06-14-2010, 04:25 AM
THAT is one BADASS picture!!!
2003 Black H2:
2006 Blue H2:
06-14-2010, 04:56 PM
air ride suspension in the back????
If so, you will need to mod teh air ride sensor arms because of the 13.5 wide tires. do a search on the forum, and you can find the how to on the mod.
otherwise, what has already been said.
a side note tho, planning on doing any off roading? liek serious off roading, not just going down a dirt road? if not, i would prolly recommend the 22 inch rims instead of the 20's.
i have the rockstars in the 20x10 flavor, and they do look damn good, i still wish i would have gotten 22's instead.
06-15-2010, 12:12 AM
wooooahhh thats some serious rubber! not to thread jack but I had been looking at the toyo 37x13.5's although that picture is making me give that idea some second thought.
2004 white H2 SUV lux
06-16-2010, 03:36 AM
Thanks for the comments. Don't wanna thread jack either just wanted to show you can fit 37's not have to much rubbing if the offset is right. The tires look huge cause they're mounted on 12" wide wheels. The width of the wheels made a huge difference on the way they look, I had them on stock wheels before and they looked puny compared to how they look now.
03 White H2
06 kawasaki stx-15f
02 yamaha superjet
