07-06-2010, 05:59 AM
Resetting Avg. Fuel Economy
We ended up buying the 2006 Pacific Blue Limited Edition (pictures forthcoming). I'm trying to reset the Average Fuel Economy but I don't know if I'm actually doing it correctly. The Owner's Manual says to press and hold the select button for one second. Is the value supposed to be reset to zero? It stays the same for me.
Thanks.
07-06-2010, 06:06 AM
Re: Resetting Avg. Fuel Economy
Never mind, I figured it out.
07-06-2010, 06:21 AM
2004 white H2 SUV lux
07-06-2010, 08:33 AM
Why don't you share what you did. Might benefit others in the forum with the same question.
2004 Black H2
07-06-2010, 10:21 AM
With the Avg economy visable in the info center, press and hold the select button for 1-2 seconds, the counter will reset to 0.0
07-06-2010, 01:15 PM
I rarely reset the mpgs unless on vacation, but I reset the gallons used with the <__] steering wheel button every time I fill up.
07-07-2010, 12:31 AM
Also works to reset the oil life %. I reset after each oil change.
2006 H2 SUT Fusion Orange LE
07-07-2010, 12:46 AM
My fuel used has never been reset from what I can tell. I know I have not reset it. 1,729 gallons for 21,500+ miles. Around 12.4 mpg average.
2005 H2 Desert Sand Lux with partial adventure package
Show me a H2 owner with low profile street tires and I will show you a guy who thinks the coolest way to shoot a Glock is cocked sideways.
07-07-2010, 09:27 PM
I followed instructions...
07-07-2010, 11:30 PM
My 2004 doesn't reset to zero using instructions here....holding down Select button...so thought you might have tried something else
2004 Black H2
07-08-2010, 03:06 AM
The select button did the trick.
