Old 01-11-2011, 08:58 PM
kmleong kmleong is offline
kmleong is on a distinguished road
Default Re: Need to buy a wiper motor and module. Where from?
Thanks Bluethunder, I did a little further checking on this.
GM Parts Direct sells at $58.32.
GM Parts Worldwide sells at $71.47 & $48.00 S/H for a total of $119.47.
Locally I got it for $155.68 CDN., taxes in from the dealer because I couldn't wait for 4 - 21 days for GM Parts Worldwide. The new part has a thicker gasket. I had great difficulty in getting it compressed enough to get the latches to catch. Hopefully it works this time.
2004 H2 Lux; Night vision, Helix Tower power 11, Volante CAI, Diablo Predator, Bluestar, 20" Weld Racing, 325/60 Terra Grapplers, Rancho 5000's + Steering Stabilizer, XTC Lightbar,Hella driving lights, Compustar Alarm + Remote start, 2 Elec. fans, Tru cool 4739, oem Rear camera,console vault
Old 01-13-2011, 09:49 PM
Biskxp's Avatar
Biskxp Biskxp is offline
Biskxp is on a distinguished road
Just had my rear washer go nuts too - Read through the thread - grabbed some tools and went to work.
Had a bit of moisture build up on the pcb cleaned it up but still had the same problem with the rear washer pump running continiously. New PCB time....
However being totally bloodyminded I took the board out of the cover, cleaned it again and dug a multimeter out..........
And the findings are.......
One resistor at the bottom of the board had water damage and had dropped from about 380 Ohms to 11 Ohms which instantly engaged the wash relay on the underside of the board.
Name:  Wiper Module 1 wet.jpg
Stole a pic and marked the resistor.
Removed resistor and all now works perfectly though one day I suppose I ought to get round to putting in a replacement.
Due to the location of the resistor I imagine this is the main cause of the washer going nuts so I hope it helps some people
Old 01-13-2011, 10:46 PM
Easy Ed Easy Ed is offline
Biskxp, You didn't steal it you improved it
Thanks for the heads up on the resistor, I would not have figured it out
Ed
Old 01-13-2011, 10:57 PM
BLUETHUNDER BLUETHUNDER is offline
BLUETHUNDER is on a distinguished road
Attachment 53209
Thanks for the tip.did you remove it completely???.
Old 01-13-2011, 11:05 PM
Biskxp's Avatar
Yeah removed it completely. 2 second job with a soldering iron. Just been for a drive and all seems to be working no problems now!
Old 01-14-2011, 06:14 AM
[__--MUD--__]'s Avatar
good job diaging the bad component! Most ppl would of just said F it and bought a new one.
Old 01-14-2011, 01:23 PM
Biskxp's Avatar
The trouble of living in the UK is trying to source the parts quickly - I should have a new one heading to me - in a week or so. And as someone who has to sort fked electronics on a daily basis I thought it was worth at least a quick look!!
Old 01-14-2011, 09:20 PM
GM Parts worldwide has been a good service. Posted on the 5th Jan. Cleared customs and delivered on 9th. Still not as good as Rockautos though. I recieved a brake caliper from them for the H2. Ordered and delivered within 2 days.
Old 01-14-2011, 11:25 PM
Biskxp's Avatar
Good to know. Had the old girl 3 years now and stacked 70,000 miles on her. Now getting all the little problems you get 2 days after your extended warranty has finished.......
Old 01-15-2011, 12:10 AM
Nice to know a fellow Brits on here.I was beginning to think i was the only one.
Old 01-30-2011, 07:04 PM
Just an update on this. Finally got around to fitting the new circuit board yesterday. All the problems are now solved and everything is back to normal
Old 05-27-2011, 04:37 PM
PaHumBug's Avatar
PaHumBug PaHumBug is offline
Blue Thunder,
I can't find the cover and circuit board. What website and what part number did you use? I've dried out and resealed mine twice, but my wipers only work when it's NOT raining (of course), so I'm going to replace my circuit board.
Old 05-27-2011, 09:22 PM
H2ummer H2ummer is offline
H2ummer is an unknown quantity at this point
Gene Culley at http://www.gmpartshouse.com/ can help you.
I buy Hummer and Corvette parts from him. His shipping is much cheaper than GM Parts Direct.
Wendell
03 H2 Pewter W/Lux, with 05 Navigation Radio and XM added. (Sold)
07 H3 Slate Blue W/Lux, Off-Road, NAV, Sunroof, XM, Tow, Auto (Sold)
08 H2 White W/Lux, NAV, Air Sup.
