Old 04-05-2011, 12:33 PM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default Front Hub Replacement
Well my H2 only has 47K on it and the darn front hubs are bad. I was wondering if anyone has any advice on changing these...
Any special tools, sealants, precautions....
Does anybody have photos of it or manual they can post.
Thanx
Old 04-05-2011, 01:31 PM
Dug Dug is offline
Dug is off the scale
Default Re: Front Hub Replacement
Both of your wheel bearings are gone at the same time? Thats not normal and especially at 47k.
Not to hard to change and not any special tools. Take tire off , take brake caliper off , take brake rotor off , remove large axle nut , unplug abs wire , remove four bolts holding the wheel bearing assymbley on. Remove wheel bearing assy and install new and put back together.
Old 04-06-2011, 06:44 AM
SmokeyJoe's Avatar
OK sounds pretty easy, and I watched a video on youtube by Timken.
Does anyone know the size of the axle nut?
I also read the axle nut is torqued to 176 ftlbs --- is that correct?
Thanx
Old 04-06-2011, 05:37 PM
Dug Dug is offline
Not sure of the axle nut size I think 36mm , but we always get them off with a standard fraction socket. Im pretty sure its 177ftpds.
Old 04-07-2011, 06:29 AM
SmokeyJoe's Avatar
Dug - No not both hubs are bad just the passenger side, but I decided to replace both sides at one time.
I will be putting bigger tires on soon and just dont want the head ache later.
Thanx for the info too!
Old 04-12-2011, 07:17 PM
FiremanJay's Avatar
FiremanJay FiremanJay is offline
FiremanJay is an unknown quantity at this point
found this site when i had to replace mine, i have done it for mine and a buddys pretty easy to do.
http://duramaxdiesels.com/forum/showthread.php?t=265
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
Old 04-13-2011, 11:58 AM
SmokeyJoe's Avatar
Finally got one of my hubs, I will be putting it on tonight. I tore it all down over the weekend so it should go pretty fast.
*** Something I noticed though, neither side has the hub dust cap. Does the H2 not have one???
Cognito UCA - Leveling Kit - Kryptonit Tie Rods - Bilstein Shocks - Cognito Support Kit - 37X12.5 Cooper Tires - Pro Comp 8128- Mercury Balancers
Old 05-29-2011, 09:34 PM
plantman plantman is offline
plantman is on a distinguished road
I just did my front left hub very easy, but does anyone know how to reset the four wheel drive my 4-wheel service light now comes on will not engage
