Old 12-07-2010, 11:49 AM
roumieh2000 roumieh2000 is offline
roumieh2000 is on a distinguished road
Default Knock sound from the Rear Side - Differential Side
Dear All
I am running a GM Hummer H3 Standard; doing 50Ks on it and I am having an issue back since 3-4 months where I am hearing a knock sound from the back side (probably at the end of the shaft in the cross connection with the Differential) when I press on the gas pedal almost everytime I start moving or even when I am on the go as I am stepping a normally on the gas.
Any Ideas about the type of service that I will be involved in !?!
Old 05-12-2011, 05:21 PM
Mr_Pat's Avatar
Mr_Pat Mr_Pat is offline
Mr_Pat is an unknown quantity at this point
Default Re: Knock sound from the Rear Side - Differential Side
Just had the same issue... My 08 H3 Just got towed to dealership....
Old 08-31-2011, 02:13 PM
wordstew wordstew is offline
wordstew is on a distinguished road
Have your rear and front joints checked. I had the same issue and it turned out my rear joint was shot and the drive shaft was causing all those clanking noises.
