02-01-2012, 05:35 PM
Re: Regearing?
If you struggling with the idea of 4.10 vs. 4.56 then I would suggest using the calculator to see what your highway cruising RPM's will be, if you will be fine with the 4.56's then I would go that route as it will likely yield better mileage and pick up around town and have a minimal effect on highway mpg's.
Also keep in mind that while 4.10's will get you back to stock RPM's you are still moving a larger amount of unsprung weight with larger wheels tires so you likely will still be a bit short on performance vs. stock with the 4.10's.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
02-01-2012, 06:12 PM
Re: Regearing?
I think that just convinced me! I will look at 4.56s on trailduty.com for a decent price. Thanks for the help guys! I would have known what to do if I had the 4-speed but I wasn't exactly sure with mine.
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
02-01-2012, 08:59 PM
Re: Regearing?
what have we determined would be good on the 4 spd? and how will the gearing effect highway driving along with city driving? i dont wanna be cruising at 65mph and 2500RPM or anything.
2012 Porsche Panamera 4
02-01-2012, 09:11 PM
Re: Regearing?
I guess I don't see how 'how many speeds' your tranny has would effect a person's decision on what gears to purchase for the diffs.
It's all about the ratio of the drive shaft to the diffs...unless I'm missing something.
CNTRY
DTOM
02-01-2012, 11:09 PM
Re: Regearing?
For your truck I've seen/heard 4.56s and 4.88s..charles06 runs the same setup as us and he has 4.88s, he loves them.
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
02-02-2012, 02:49 AM
Re: Regearing?
I too am running 4.88's and 40's on the tires; I love it and drives great on city streets and on highway. The only part where I am having a power struggle is when I get going over 70mph and there is any incline in the road. This will cause my ride to struggle a little bit on power and causes it to jump into 3rd gear. I am rocking the 4 speed too though, so I know that the power distribution will be different if you have a 5 or 6 speed, so keep this in mind.
I have been researching to see what is going to be the best option for me to fix this dilemma. I want to avoid the supercharger based on the ridiculous cost, so I am looking into the following: a turbo, a custom tranny, any little upgrades like a throttle body spacer, any other custom works to get the added muscle I need to roll at higher speeds. If it comes down to it and I end up having to go the supercharger route, than I will more than likely buy a new crate engine that is more powerful than my existing one and spend the $5 G's towards something that won't blow up.
Then again, I am always open to feedback from you pros out there who have been there, done that...
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
02-02-2012, 04:14 AM
Re: Regearing?
Get a DMAX conversion!
Consider this....The GEICO commercial with the little piggy flying down a zip line of a snow capped mountain - Just before he passes the chump on the opposite zip line, he pauses and says "Pure Adrenalin...Weeeeee....Weeeeee?Weeeeee" That is the exact feeling you'll have after driving a DMAXed H2! GET A MF DMAX conversion!!! You will not be sorry. 'Nuff Said!
02-02-2012, 01:52 PM
Re: Regearing?
for what....around 25K.... there has to be a cheaper way to get good power without going boosted or swapping in a diesel.
02-02-2012, 02:33 PM
Re: Regearing?
I'm still able to pull up slight inclines without the truck downshifting at speeds over 70mph. I think the long-tube headers made a big difference, too.
02-02-2012, 04:21 PM
Re: Regearing?
i think im going to start with a tune before i jump into gears. that will be my last resort if i dont notice any improvement from the tune.
02-02-2012, 06:12 PM
Re: Regearing?
You won't. Same thing I did.
02-02-2012, 06:19 PM
Re: Regearing?
I'd just do the gears...it's not terribly expensive or complicated...and it has DEFINITE gains that you will DEFINITELY notice.
...and, plus, you may be up for a diff fluid change anyway. Kill two birds with one stone.
CNTRY
DTOM
02-02-2012, 06:20 PM
Re: Regearing?
I absolutely recommend 4.88's if you're going to spend the money for new ring and pinions. Throttle response will be dramatically better and if you choose to run 40's down the road or tow, you'll make it easier for your motor to get the power to the wheels.
2005 Black LUX
37x13.50R17 Toyo MT
Torsion keys. 2" rear coil spacers
2" wheel spacers
In Tune I2, Air Raid Filter, Air Raid MIT, throttle body bypass, straight pipe exhaust
Cognito UCAs. Kryptonite UCA ball joints. Kryptonite tie rods. Kryptonite death grip Idler. Moog HD pitman.
5.13 gears. E-locker front
Bilstein stabilizer
02-02-2012, 07:12 PM
Re: Regearing?
This has become a good little thread..  keep it up! And charles06 would you please post some pics of your rig!!
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
02-02-2012, 07:38 PM
Re: Regearing?
I know. I know. Still being lazy.
I agree with the 4.88's. You won't notice the 4.56's enough.
02-02-2012, 08:13 PM
Re: Regearing?
actually, before i bought my truck off the lease, i had all the fluid flushed and changed. now running royal purple in the diffs.
wont a tune be needed anyways if the gears are changed? not to mention i dont have my speedo matched up right.
02-02-2012, 08:14 PM
Re: Regearing?
so 4.88's will be good with 38" tires? what will i notice after having them installed? and will anything be compromised?
Re: Regearing?
Correct...you'll need to tune for the gears and tire size.
CNTRY
DTOM
02-02-2012, 08:16 PM
Re: Regearing?
Your highway cruising RPM will be higher but it should jump off the line...well, as much as a big metal box can 'jump.'
CNTRY
DTOM
02-02-2012, 08:19 PM
Re: Regearing?
