Old 02-13-2012, 09:01 AM
nasty745 nasty745 is offline
nasty745 is on a distinguished road
Default leveling kit on H2
I'm about ti install a leveling kit on my H2 sut, whats the max size tire I can go with ? I've heard 35" and I've heard 37" does anyone really know ? Thanks
Old 02-13-2012, 11:35 AM
Hellz Hellz is offline
Default Re: leveling kit on H2
35 inch tires - the H2's come stock with this
37 inch tires- These will fit on a stock h2 with no lift at all. you may have to crank the torsion bars a little, but every truck is different.
I currently run 37's on 20 inch rims. stock suspension, but have some $$ invested in the front end. New hubs, pitman/idler, shocks, tierods, steering dampner, EBC Brakes, EBC Rotors, Cognito upper control arm, MOOG upper and lower ball joints, replaced both CV joints, and had to remove my sidesteps when i first when to the 37's due to them hitting the end of the step while turning.
38 inch tires - you might be able to fit these on a stock H2, but im betting this is where you start needing to have a lift installed
39 inch tires- same as the 38's, but i would guess it becomes more of a requirement than an option. you might be able to fit them, but wont be able to make any turns. prolly can get by with a 2 inch lift
40 inch tires- you will need atleast a 4-6 inch lift. couple of guys here do run 40's, so they will be able to fill in any exact requirements.
my wish list is to move up to 40 inch tires myself, maybe even bigger! would love to pull tires off a military LMTV ( 46 inch ) and slap them on my H2.
be advised, you will be putting $$$ into your front end, and prolly pretty quick after you move up to larger tires.
as stated under the 37 inch tires, i will most likely be replacing my power steering here soon, and maybe more...
Old 02-13-2012, 04:21 PM
guruerror's Avatar
Nice write-up.
CNTRY
DTOM
Old 02-13-2012, 05:05 PM
s_c5519's Avatar
s_c5519 s_c5519 is offline
s_c5519 is on a distinguished road
Originally Posted by guruerror
Nice write-up.
Yes very nice, saves a LOT of searching and reading! Almost needs to be a sticky
Old 02-13-2012, 07:18 PM
Thanks a lot ! This definitely helps and is much appreciated.
Old 02-13-2012, 08:31 PM
guruerror's Avatar
Funny that you should mention that...I hit Jason (the admin) up last week about setting up a sub-forum under each section (H1, H2, and H3) for 'Common Problems and Fixes.' I envision it more as a 'reference' section and less of a 'discussion' area; where we post Stickys with solid write-ups about common/recurring problems, their fixes, and associated costs.
I figured this would be a good starting resource for members (particularly the newbies) when troubleshooting, or just as a heads-up on what they might need to be on the look out for. It's not always easy to find what your looking for with the search function unless you know what keywords to use. This would save some of that frustration.
Stuff like Hellz's write-up would be good to have in that section too...'Common Problems, Fixes, and Questions'
I'm still waiting to hear back...hopefully we can get something like that in the works.
CNTRY
DTOM
Old 02-13-2012, 08:39 PM
s_c5519's Avatar
Funny that you should mention that...I hit Jason (the admin) up last week about setting up a sub-forum under each section (H1, H2, and H3) for 'Common Problems and Fixes.' be good to have in that section too...'Common Problems, Fixes, and Questions'
That's a fantastic idea! I did a search for "air ride" the other day and there was 15 pages and like 350 replies to go through... In the end after you read them all and go through all the nonsense, like all of my posts usually are, it really all can be combined in nice small tidy sticky...
Old 02-13-2012, 08:41 PM
guruerror's Avatar
Well...hopefully he's checking his messages...lol.
CNTRY
DTOM
Old 06-10-2012, 07:49 AM
MARKCORE's Avatar
MARKCORE MARKCORE is offline
MARKCORE is on a distinguished road
So will 38's fit with just a leveling kit?
Old 06-10-2012, 01:25 PM
you may NOT need a kit... but then again, maybe you WILL need a kit.
install the tires and crank your T bars and let us know.
OR
install a lift and 38 inch tires
Old 06-10-2012, 03:15 PM
charles06's Avatar
charles06 charles06 is offline
charles06 is on a distinguished road
There's more to this than simply how big of a lift you have, such as off-set of wheels. I bought my truck with the Fabtech 6" kit already installed. The owner had 37" Toyo's on 22" wheels that rubbed. With about 2" extra lift from torsion keys and spring spacers, I wasn't even close, and that was with 38" Toyo's. I just made sure the new wheels had the correct off-set. I had plenty of space.
And FYI, when I switched to 40's on 22's with the same lift, which is more than 6", I had to trim the fender liners. Not sure if you can fit 40's with anything less than a 6" lift...not comfortably, anyhow.
Old 06-13-2012, 01:36 AM
slippy slippy is offline
slippy is on a distinguished road
One thing that isnt mentioned much is there is alot of variation in every truck with the torsion bars. One guys Torsion lift might just even out the factory rake, while another may be lifting 3" inches up front with spacers in the back.
That'll make a big diffrence in what tires fit....along with backspace/offset/ tire width...
Old 06-13-2012, 03:21 AM
tyler1bo's Avatar
tyler1bo tyler1bo is offline
tyler1bo is on a distinguished road
Roush did 38's at one point in time with just a leveling kit..I have no idea if they rubbed or not though. I know from my truck now, I don't see how in the world I could have shoved 38's under it without the lift.
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
Old 06-13-2012, 04:24 AM
seventwozero's Avatar
seventwozero seventwozero is offline
seventwozero is on a distinguished road
My 37x13.5 Toyo's scrub the sway bar at full lock, that's with a "green" key t-bar level, not a kit like the Truxx. I've seen "aggressive" leveling kits, that are supposed to give you slightly more lift than kits like the Truxx, you may be able to squeeze 38-38.5's with these, it's hard to say. After reading for a while, every person has different problems with their tire and lift combinations, one persons success will cause issues with another.
If I recall correctly, there is/was a member on this very board that had a H2 on 40's, and didn't have an official lift kit (like that of Fabtec/Rancho). I don't remember the name of the guy, the truck was white though and maybe a friend of Humminboatin', although I could be wrong.
edit: HERE is the rig I'm talking about. The owner says he has 'everything Cognito' up front, to which I assume upper control arms and their steering stuff, plus "green" keys. He's running 39.5" IROK's on stock wheels.
2004 white H2 SUV lux
Old 06-13-2012, 06:37 AM
Big.Z.hummin's Avatar
Big.Z.hummin Big.Z.hummin is offline
Big.Z.hummin is on a distinguished road
Roush's 38s most definitely rubbed and there was only like 20% tread left. my 37's on 17's rub at full crank and thats with the truxxx level kit. seems to be a ride particular kind of thing as stated above. i honestly think 38's with no level would rub like crazy.
Old 06-13-2012, 06:55 AM
They are really ONLY 1/2" bigger though, but 2" wider, give or take. I've been looking long and hard at the Goodyear MTR-K that are 38x15.5, I mean.. how bad can it really be?! Maybe with some 4.75 backspaced wheels?
Old 06-19-2012, 07:57 PM
wingn69's Avatar
wingn69 wingn69 is offline
Im running 37in on my H2 with very little rubbing with no leveling kit, lift kit or cranking the the t-bar but am looking at the Truxx leveling kit my self.
Old 06-19-2012, 08:14 PM
citiboy's Avatar
citiboy citiboy is offline
citiboy is on a distinguished road
i just bought the toyo mt 38x13.5x18 with rockstar rims, installing them this coming thursday....i'll crank the tb 2" and will install 1.5" rear spacer. Hopefully, i'm good to go...i can live with a little rubbing .
2008 Hummer H2 Luxury Edition
Toyo MT 38x13.50x18 on Rockstar. Green keys. 2" rear spacers. 1" bodylift. Cognito UCA, steering bracket, front stab links. Bilstein 5100 shocks & steering stab. Moog inner/outer TR, pitman, idler arm & bracket with remote zerk. E&G Classics fender flares. ARP 434-1301 ex. man. stud kit. Airaid perf. air filter. Crown brake lines. Warn PowerPlant HD. Rubberduck UCP. Gobi Ranger roof rack. DDM Tuning 55W HID Hi/Lo headlights. Hella fogs. Evans waterless coolant.
Old 06-20-2012, 08:41 PM
let me know how this setup works for you.
i wouldnt mind moving up to 38's i just dont want to install a lift kit
