Old 03-28-2012, 05:05 AM
Boosted Boosted is offline
Boosted is on a distinguished road
Default Automatic Headlights wire for Stereo
I am trying to wire up my Clarion NX700 head unit so that the Navigation will automatically go to the night setting when the headlights come on. Any idea where i can find that wire? Prefferably inside the cab.
Thanks for any input.
Old 03-28-2012, 06:48 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Automatic Headlights wire for Stereo
You will need a class 2 interface module as the bcm controls the auto headlight function over the data line
1998 Chev Z71
2007 Chev Trailblazer SS
Old 03-28-2012, 07:05 AM
Wow, that went straight over my head. Any more insight into this?
Old 03-28-2012, 07:14 AM
BCM = Body Controll Module . Got it.
I can not find the "class 2 interface module". I have looked for PAC items and do not see such an item.
Old 03-28-2012, 02:15 PM
guruerror's Avatar
Maybe my memory is shot...but when I installed my AVIC years ago, I'm almost positive that I was able to tap into a wire on the headlight switch to get a 12v signal indicating that the headlights were on (I don't remember which one...seems like it was 'green'). I'm pretty sure I linked that up to the 'Illumination' line on the head unit and everything worked as you describe.
CNTRY
DTOM
Old 03-28-2012, 07:20 PM
HUMTECH's Avatar
1998 Chev Z71
Old 03-28-2012, 07:22 PM
HUMTECH's Avatar
Tapping into circuit 2353 before the cluster should work
1998 Chev Z71
Old 03-28-2012, 10:36 PM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
You would have to keep your dimmer control all the way up though to do it this way so the radio see's the full 12vdc as that circuit is behind the dimmer control.
Old 03-28-2012, 11:17 PM
guruerror's Avatar
Depends on whether you tap before or after the potentiometer...I'd think.
CNTRY
DTOM
Old 03-29-2012, 03:13 AM
HUMTECH's Avatar
Yup I see the problem with that circuit now. This is the one you want, circuit 1970 at the bcm connector c2 pin a4
1998 Chev Z71
Old 03-29-2012, 03:15 AM
HUMTECH's Avatar
Actually that prob wont work, needed to be 12v control in bcm not ground control, ill keep looking lol
1998 Chev Z71
Old 03-29-2012, 03:17 AM
HUMTECH's Avatar
Circuit 712 is the only way i see it working, under the hood unfortunatley
1998 Chev Z71
