05-18-2012, 11:55 PM
Road Rhino Bumper, Rubber Duck Brush Guard, E&G Wide Flairs
05-19-2012, 12:02 AM
Re: Road Rhino Bumper, Rubber Duck Brush Guard, E&G Wide Flairs
I dig it. I've been curious how this combo would look. Looks mean as hell.
2005 Black LUX
37x13.50R17 Toyo MT
Torsion keys. 2" rear coil spacers
2" wheel spacers
In Tune I2, Air Raid Filter, Air Raid MIT, throttle body bypass, straight pipe exhaust
Cognito UCAs. Kryptonite UCA ball joints. Kryptonite tie rods. Kryptonite death grip Idler. Moog HD pitman.
5.13 gears. E-locker front
Bilstein stabilizer
05-19-2012, 12:04 AM
Adapter plate that was made to work w/ the bumper
I was going to put that Rigid 20" light bar under the winch where that damn logo is, but it looks alot better above the bumper.
I'm **** canning that logo...
Small light hole will be filled, larger curcular will be shrunk down and square. Light bar will be centered in that opening- Mounted to the hunge so it flips w/ the hood.
05-19-2012, 12:10 AM
bumper corners will be extended out to protect the flairs...
Rear Bumper will have matching style corner guards.
About 30 other mods going on I'll get into later...
Bumper and brush guard was provisioned for a 2" body lift...Just havn't made a final decision if I want to add more height to the truck yet.
06-03-2012, 10:32 AM
Did they sell you those bumpers without being fully welded? Great work by the way, but not sure how you are going to adapt the front bumper to work with a 2" body lift???
(unless you cut the frame and raise it up 2" in the front)
06-03-2012, 10:40 AM
06-04-2012, 07:48 PM
I believe you can choose to weld the bumpers yourself for a slightly discounted price. As I want to add a 2" body lift that should make it easier to get things looking sharp.
2005 Black LUX
37x13.50R17 Toyo MT
2" wheel spacers
Bilstein stabilizer
06-04-2012, 11:42 PM
Front and rears pre bent in about 30 pieces was $700 carry out in chicago. I have changed a number of things on the kit- whats pictured is about 85% of what you get.
Bumpers would stay in the existing spot. Winch and brush guard are both custom mounted to the frame also. I didn't want to have anything pulling on the bumper itself. I have a filler that would just get welded on top of the bumper. You'd never be able to tell its a filler panel after the welds were ground down and painted. Brush guard would get holes drilled equal height of the body lift to raise that also.
07-25-2012, 03:53 AM
Mud, any finished pictures yet?
07-25-2012, 01:25 PM
Just one word for all your work - AWESOME! I love it.
07-25-2012, 02:32 PM
CNTRY
DTOM
07-25-2012, 04:15 PM
07-25-2012, 04:28 PM
Wow, can't wait to see the finished version.
2008 Hummer H2 Luxury Edition
Toyo MT 38x13.50x18 on Rockstar. Green keys. 2" rear spacers. 1" bodylift. Cognito UCA, steering bracket, front stab links. Bilstein 5100 shocks & steering stab. Moog inner/outer TR, pitman, idler arm & bracket with remote zerk. E&G Classics fender flares. ARP 434-1301 ex. man. stud kit. Airaid perf. air filter. Crown brake lines. Warn PowerPlant HD. Rubberduck UCP. Gobi Ranger roof rack. DDM Tuning 55W HID Hi/Lo headlights. Hella fogs. Evans waterless coolant.
07-26-2012, 01:10 AM
Sick..sub'd for more!
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
07-26-2012, 01:33 AM
15 months?! Well.. they don't call em builds for nothin!
It's going to be one badass H2 when you finally finish it up!
2004 white H2 SUV lux
07-26-2012, 02:58 AM
So Mud, when you gonna start building custom bumpers for H2's? I'll be the first order...
07-26-2012, 03:02 PM
Put me on the list!
09-16-2012, 08:46 PM
How's the progress on the bumper? Can't wait to see it finished.
09-17-2012, 12:15 AM
been going back and forth w/ Amp Research (the guys that make the power steps). I bought an extra side step and was going to mount it off the rear bumper. The rear hitch combined w/ the distance the steps opens out was preventing me from tucking it up behind the bumper. Finally got a hold of a guy at Amp that actually knows all the various kits, how they open, mount, extend, etc... and got a bracket that completely will tuck up and behind the bumper. It has dual motors- one drops the other extends. So I'm sending back the parts I have now in exchange for this new setup.
I have a 12 gallon air tank mounted up behind the bumper, a 50' enclosed/sealed airhose reel.
Rear end diff is out, had issues w/ the stock carrier. It was machined incorrectly from Eaton and GM didn't track what vehicles got the carrier. Eaton said to send it to them, they machined the face the gear sits on and shipped it back at no cost. Couldn't believe they backed that up. Pretty ****ing unbelievable support as far as I'm concerned.
I had a complete chromoly steering setup made. Everything between the hubs all custom. They didn't cut the idler and pitman splines correctly and somehow lost my centerlink. So they had to remake all that **** again, powercoat it and its supposed to be here tuesday.
I've been trying to get this carbon fiber hood vent from this jack ass in florida since february. Finally found someone local there to go get it from the guy.
I used to hear about builds taking years to get done thinking it just being lazy...There is jus so much crap that depends on this or that, I can't do this untill something else is done, etc... but progress is being made.
09-17-2012, 04:59 AM
Wow... Sounds like your redoing everything, also sounds real expensive! The truck looks great thus far. When your done with all this its going to be one bad mother. I'm impressed.
I've been planing things for my truck in reverse order... Like bigger gears, upgrading the steering and the brakes. Maybe if I start under the truck and work my way out my wife won't notice all the money going into the truck until I through the lift and tires on... Unlikely, but we shall see.
