Old 11-02-2012, 10:16 PM
devilsfan's Avatar
Default AC blowing hot air when off?
I had the main board replaced on my AC a few years ago. Lately, I noticed that when I turn the system off, it blows hot air through the vents. I have to turn it down to 60F, THEN turn it off to prevent this from happening. It never did this prior to the AC work. Thoughts?
Old 11-02-2012, 11:37 PM
[__--MUD--__]'s Avatar
Default Re: AC blowing hot air when off?
Blend door actuator. Its what regulates the hot/cold air.
Old 11-03-2012, 03:51 PM
devilsfan's Avatar
So I did some google on the blend door actuator....my system is running fine when it's on - keeps cold and hot no problem. The hot air only comes out when the system is turned OFF. If the actuator was bad, wouldn't the AC not run normally?
Old 11-03-2012, 06:22 PM
What are you calling "system"?? The entire hvac or just the ac unit?
Old 11-04-2012, 01:26 AM
devilsfan's Avatar
I guess the AC. Because if it blew hot air when the heat was on, then that wouldn't be a problem then, right?
Old 11-04-2012, 04:24 AM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Hopefully it's not the Blend door actuator ... I just replaced mine what a PAIN IN THE ARSE!!! It drove me NUTZ and cut my hands up!! It's a 10 on the SUCK Scale!!!
Old 11-04-2012, 05:35 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
I dont suppose you have your hvac system on auto climate control when this happens do you? If so your inside air temp sensor reading may be causing your problem. It will default to -40c if its not working and try to heat up the cab
1998 Chev Z71
2007 Chev Trailblazer SS
Old 11-05-2012, 12:35 AM
devilsfan's Avatar
It's always on auto - interesting! So how would I test if it's the sensor or the actuator?
Old 11-05-2012, 02:26 PM
guruerror's Avatar
Mine has always done this...whatever my last HVAC setting was (temperature and output vent), once I turn it off it still blows; just a little bit. Every other aspect of the HVAC seems to work fine...
I simply got in the habit of changing the output vent to the defroster before shutting it off.
CNTRY
DTOM
Old 11-07-2012, 10:45 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
mine does the same thing when turned off, it seems like the vent kicks open and lets the hot air through the vents. I don't think you can turn on recirc without the system on?
Old 11-07-2012, 11:37 PM
devilsfan's Avatar
Well, glad to see it's a common problem. It's not worth me paying out of pocket for at the dealership, that's for sure. I'm going to start trying the defrost setting trick, that sounds like a really good solution.
