Old 04-24-2006, 11:33 AM
I noticed it when we stopped for gas yesterday, but didn't pay much attention.
The vehicle comes to a halt in tight turns. The tighter the turn, the more resistence I'm getting. It feels pretty weird but doesn't seem to be interfering with the vehicle too much.
Any ideas?
Old 04-24-2006, 01:55 PM
Good question. I think it's worse to turn left than right.
Old 04-24-2006, 02:58 PM
They do appear normal and the truck seems to drive okay when going straight or making slight turns. It only occurs when I am turning tight.
Figure it's okay to drive until it breaks?
Old 04-24-2006, 03:10 PM
I'm betting it's the CV. It's "tightening" up for some reason when you turn tight. Take a quick look at the boots and see if you have any tears. You might have torn one on something and over time water/dirt/grit contaminated it. Or it could just be the bearings going out.
Old 04-24-2006, 06:19 PM
The boots on the CVs look okay and the sway bar is defintely in place.
Old 04-24-2006, 06:46 PM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
Definately a CV joint issue, if you're out of warranty, take it off and have it rebuilt at a drive train specialist for under $100. It is probably contaminated grease causing the balls to stay in the grooves of the cage.
Old 04-24-2006, 06:53 PM
The warranty will cover it, I'm sure. I will try to get it in to the shop tomorrow.
Old 04-24-2006, 08:44 PM
Tire pressures good? Not in 4Hi lock?
Old 04-24-2006, 08:47 PM
Checked and checked.
Old 04-24-2006, 10:55 PM
dochummer's Avatar
Don't forget your alignment...
'03 H2
Old 04-25-2006, 02:23 AM
Adam, you were really struggling to turn your truck while in Moab. Much more than we were when we were aired down.
Get that thing fixed, buddy.
Old 04-25-2006, 01:47 PM
In the shop now.
Old 04-25-2006, 03:24 PM
So, they're telling me the truck is locked in 4 Hi. ???
