03-26-2004, 05:54 PM
I just hit 20k, other than a couple of tire rotation and oil changes, what else do I need to do?
03-26-2004, 06:24 PM
I am pretty sure at 20k miles you are supposed to give it to me, would youi mind delievering it to HIllsboro Oregon if its not too much trouble ?
“Slow response”
You must be imagining it,
Your port is routed Via a Net Optics Net1000SX to a Finisar Multi-Mode GBIC, from there your packets Travel over a 850Nm Laser connection to our High speed 7800KB/sec Max Optical Storage device, I see
03-26-2004, 06:33 PM
Scheduled Maintenance
Engine Oil and Chassis Lubrication Scheduled Maintenance
Change engine oil and filter as indicated by the GM Oil Life System (or every 12 months, whichever occurs first). Reset the system.
Your vehicle has a computer system that lets you know when to change the engine oil and filter. This is based on engine revolutions and engine temperature, and not on mileage. Based on driving conditions, the mileage at which an oil change will be indicated can vary considerably. For the oil life system to work properly, you must reset the system every time the oil is changed.
When the system has calculated that oil life has been diminished, it will indicate that an oil change is necessary. A CHANGE ENGINE OIL message will come on. Change your oil as soon as possible within the next two times you stop for fuel. It is possible that, if you are driving under the best conditions, the oil life system may not indicate that an oil change is necessary for over a year. However, your engine oil and filter must be changed at least once a year and at this time the system must be reset. It is also important to check your oil regularly and keep it at the proper level.
If the system is ever reset accidentally, you must change your oil at 3,000 miles (5 000 km) since your last oil change. Remember to reset the oil life system whenever the oil is changed. See “Oil Life System” in the Index for information on resetting the system.
An Emission Control Service.
Lubricate chassis components with each engine oil and filter change. Lubricate the front suspension, ball joints, steering linkage, transmission shift linkage, and parking brake cable guides. Ball joints should not be lubricated unless their temperature is 10_F (-12_C) or higher, or they could be damaged.
7,500 Miles (12 500 km)
Check rear/front axle fluid level and add fluid as needed. Check constant velocity joints and axle seals for leaking.
Rotate tires. See “Tire Inspection and Rotation” in the Index for proper rotation pattern and additional information. (See footnote +.)
15,000 Miles (25 000 km)
Inspect engine air cleaner filter if you are driving in dusty conditions. Replace filter if necessary.
22,500 Miles (37 500 km)
03-26-2004, 11:16 PM
Turn around and go back now.
________________________
This place sucks now, bye.
03-28-2004, 02:00 AM
Sell it fast. Then run out and buy a new one.
03-28-2004, 02:55 AM
Well I just turned 54,000 miles on mine. Had the transmission serviced last week and the fluid was in great shape and the filter rather clean.
